This is a spalted hard maple platter that I turned this afternoon, 12" diameter, no finish applied .........yet.
For those of you who turn spalted wood, what finish do you like that keeps the spalted contrast? I used some cut-off pieces to test my finishes and all 5 finishes turns it to "mud".
Minwax Wipe on poly will seal and finish with several coats or General Finishes Oil based Salad Bowl Finish will build and is a bit less yellowing. I have found sealing with a lacquer sanding sealer and then applying the General Finish cuts yellowing even further. I wipe the General Salad Bowl finish on with a wad of old 100% cotton T-shirt very thinly and several coats to build. First coat generously and then thinly. Can get three coats on in a day.
I'm not a fan of General's Salad Bowl finish. Yellowing of any type, isn't an option. Thought about General's water based finishes, like the Polyacrylic or Enduro??? Or possibly Krylon's acrylic finishes???
You would need a case of rattle cans to get that thing to stop soaking it up. Definitely water based or acrylic. If it's a shelf show piece, I would put nothing on it. Beautiful piece of maple!
.... is lacquer, wipe on a slightly thinned coat or two (Deft and 5~10% acetone)for sealer, followed most often with rattle can lacquer like Deft. Another option after sealer is the General Finishes Woodturners Finish, but sealer must be able to subdue the raising of grain since its a water base finish.
You definitely honored the wood with a simple shape. I think lacquer gives a good finish on spalted wood without making it look dingy like varnish does. I keep a can of brush on Deft around for things like this.
If you 'sand-in' an oil finish of any kind, you will make a slurry that sometimes is called MUD. Don't do that. A quart can of Deft Sanding sealer (about $12.00) dries water clear, seals soft and open grain. Slather it on with a saturated rag, but in moments wipe off the excess. Let it dry....do it again. Let it dry...do it again. Sand between coats and down to 600 grit. Wait a few days and buff it with carnuba wax wheel...soft and slow. Your finished product will be bright and contrasts will remain. You will get a minute darkening (try a little on scrap to be sure) . If it is going to be subjected to everyday use, cover the finished piece before waxing with a coat of something that is harder than the lacquer...waterlox maybe.
For spalted wood I use Qualalacq sanding sealer which has more body than plain lacquer. I apply it, allow it to dry which is nearly instantaneous and then cut back with steel wool to remove any unevenness. I usually do this on the lathe which makes cutting back much easier.
After a couple of coats, if it takes that many, I top coat with Qualalacq lacquer thinned 50% for more control or if I am feeling particularly lazy rattle can lacquer.
Qualalacq is non-yellowing and holds up very well.
I did several pieces of sugar maple that looked similar to yours, a couple of them were quite firm, and used 60% lacquer, 30% lacquer thinner, initially, twice, allowing to dry completely a day or two, sand smooth and then spray lacquer.
I like this method because it does not change the color much.
The pieces that were softer got a different treatment, a low viscosity epoxy called Mirror Coat, seal one side with masking tape apply generously the 2 part epoxy in the other, and watch it travel in, repeat until it sops drinking. Next day, peel of the masking tape, you may need to scrape it if the epoxy went though and then apply more epoxy where the tape was. Wait a day again and then re-turn or just sand away until it is where you like it. It darkens some but not really objectionable.
What I've done a lot with spalted maple is to brush on a coat of lacquer sanding sealer (Deft), let it dry, and then sand it until it is almost gone. Then, perhaps, repeat the process. (Sand with 320 or 400 grit, or use 0000 steel wool.)
The result is a surface that is slick, sealed, and hardened, but not shiny. Depending upon how much you sand, the wood may appear not to have any finish on it at all, even though it does.
The sealer will impart a distinct amber color to the wood when it is first applied, but the amber cast will go away as the sealer dries. (It might take 24 hours.) However, try the process on a test piece before you go for the gold.
