Bradford Pear won't Float!
Doc Green
While everyone else is headed to Tampa, I'm stuck here in NC cutting up a Bradford pear tree that went down in a recent storm. The tree belongs to my neighbor. I'm cutting it up for the wood.
My impression is that it sure is heavy. (Sun is hot too.) So, while taking a break, I weighed a sample of it, took some measurements, and soon figured out that a 12" long section of the 22" diameter trunk weighs 165 lbs. No wonder I was huffing and puffing while trying to load it on my lawnmower trailer to haul it across the street!
Noticed that its specific gravity is more than 1.0, which implies that a piece of it will not float in water. Had to try it. Sure enough, a sample of the wood placed in a bucket of water went straight to the bottom. Not even close.
This is the first time I've seen a piece of local North Carolina wood that wouldn't float, and I've checked green oak, walnut, cherry, etc. Who would have thought that Bradford pear would be heavier than oak?
Hope all the travelers have a safe trip to Tampa!
~Doc
Re: Bradford Pear won't Float!
Mike Peace
Mike Peace
It is one of my favorites for turning. A bit of a mystery that it grows so fast but can be so hard when dry. Turns wonderfully but can bruise easily if you ride the bevel too hard.
John lucas
I thought lignum vitas was the only wood that would not float but I've never looked up the specific gravity of other woods.
Don Stephan
Love this wood for once turned bowls, as it warps wonderfully with minimal risk of I'm guessing the marvelous ornage-rust color develops as a result of sunlight. Danish oil is a great finish for this wood, in my opinion.
only when wet...
GaryG in MD
Hi Doc,
If you think about it, the density of wood is measured dry.
Wet woods are clearly denser than their "standard" values.
According to Table 2 in
http://joa.isa-arbor.com/request.asp?JournalID=1&ArticleID=3004&Type=2
the specific gravity (GS in the table) for their two dry samples of Bradford Pear (Pyrus Calleryana) ranged from 0.67 to 0.69. So it's not close to sinking when dry.
John, Lignum vitae is far from the only wood with a dry density greater than water. Other examples are chechen, cocobolo, cumaru, ebony, african blackwood, marblewood, satinwood, snakewood, verawood, and others.
FYI, my excellent source for density values is
http://ejmas.com/tin/2009tin/tinart_goldstein_0904.html
This is actually primarily an excellent hardness reference, but it also has density values. (Water is 62.4 lb/ft3.)
...GG
William Duffield
It depends on whether you are talking about green or seasoned wood. Lignum vitae will sink even at 0% moisture content, but most woods will sink when freshly cut and totally saturated with water. Thus we have a market for submerged logs that have lain at the bottom of rivers and lakes for a century or more, because they sank between being cut in the forest and the saw mill.
Lignum is not the only species that sinks when totally seasoned, but there aren't many. Another example is bloodwood, or satine, but not all specimens of that species sink. If you're interested, check the specific gravity specs listed at the USDA Forest Products Lab Center for Wood Anatomy Research.
Re: only when wet...
Bob Macgregor
...and desert ironwood (SG 1.2); also a bugger to saw!
BOB
