Delta DL-40 lathe...HELP
Janice Manuel
Help.....my lathe that I use almost daily is not working....started having trouble with it dropping speed a couple weeks ago, and it quit yesterday. A google search turned up some info..mostly that my now 20 yr old machine had issues with it's electronic speed control system. Does anyone have a schematic for the main control board? From what I read, Delta has no replacement parts available for this machine anymore...
Worst case is we have to replace the motor and controller...currently, it has a 1.25 hp DC motor which has always been enough for me. I'm a spindle turner...Any suggestions as to what to replace it with? I have someone who can do the repair...I am not sure yet if the motor is going bad, or just the controller....
I don't want a new lathe...I need this one working...
Re: Delta DL-40 lathe...HELP
John Veerkamp
Janice,
My Delta controller went bad. It was a Baldor. In KC there is a electronic repair shop that is an authorized Baldor repair shop. The guy there had it fixed while I waited, About 1 hr as I recall. I know there are authorized repair shops around the country. Maybe one around you. Sadly Delta doesn't try to maintain it's older machines. If you can find the controller model and S/N inside the cover you can usually find a replacement available.
Good luck.
BTW any more long bike rides?
John
