THE WOODRAT IS BACK!
cutting black pipe for clamps
Brad Bransky
Before I ruin a hack saw blade, I thought I'd check with you all for advice. Black pipe for Pony clamps can be bought cheaply in ten foot lengths. Can they be cut with a hack saw?
Incidentally, a few weeks ago I asked what causes edge snipe at the end of a cut on the jointer. I got some good answers and advice. I discovered the culprit is too much hand pressure on the rear end of the board as it crosses the blades. If I keep my hand well in front of the right end of the board I get no snipe. So thanks to which of you suggested same.
Brad
Re: cutting black pipe for clamps
Brad Bransky
Ooops! Sorry, wrong message board. Brad
Rob Wallace
Rob Wallace
Brad:
I have cut black pipe with a bimetal blade (Dewalt) mounted in my Sawsall; use slow speed with modest pressure, and let the blade do its job. It took some time, but cut fairly well. A few drops of cutting (threading) oil can extend the life of your blade if applied a few times during the cut.
Rob
bill Crommett
Better yet, use a pipe cutter. Less effort, smoother ends , less filing.
Don in Central Illinois
At our local Ace Hardware, I just tell them I need two five footers ( as an example) and they cut and thread the ends at no extra cost.
I found that some big box stores....
JamieDonaldson
...that specialize in building supplies have a selection of pipe cut to a variety of lengths, and already threaded for the clamps. I also prefer galvanized pipe that doesn't rust and make a mess on my project glue-ups.
