Grinders
Willie Simmons
If the guard is not needed for CBN wheels is there any thing wrong with using a six inch wheel on an eight inch grinder or an eight inch wheel on a six inch grinder.
Grinders
Willie Simmons
Re: Grinders
Jim Breeden
Shaft OD vs wheel ID ?
Re: Grinders
John Veerkamp
1725 or 3450 rpm are the same whether the wheel is 2" or 20'. If it fits use it.Most wheels these days come with adapters/ bushings for the most common shaft sizes.
I see you are demoing in Tampa
steven antonucci
Congrats. They are in for a treat.
As to your question, I think the guards are there to arrest some of the energy is the wheel breaks, rather than have it just fly radially outward. With the CBN wheels being on a metal substrate, the only question I would ask is does the grinder have enough HP to move the bigger when effectively? Barring that issue, I think you'd be OK?
Steve
surface speed?
Re: I see you are demoing in Tampa
Scott Hurley in N VA
I have a Woodcraft slow-speed grinder, and the CBN wheels work just fine. They do take a couple of seconds longer to get up to speed, though.
Re: Grinders
robo hippy
I would not put an 8 inch CBN wheel in a 6 inch grinder even if it fit. Mostly, these wheels are so heavy, I would think the little motor on the 6 inch grinder would burn up trying to run one. I still wonder if the cheap slow speed grinders will wear out faster trying to push this much weight, most 8 inch CBN wheels are over 6 pounds. It probably wouldn't hurt to give the wheel a push start before turning the motor on. I was surprised at how much difference there was in the power of my no name 3/4 hp grinder and my Baldor. Huge!
robo hippy
Willie, I'll add my congrats here too!
Willie, break a leg!
Mike Stafford
Of course that is in the best sense of the word. I hope you have a great time in Tampa and knock 'em dead with your demo.
Give my best to all the guys up there.
Re: Willie, break a leg!
Willie Simmons
Thanks for the support. I hope people come to the demos and get something from what I show. Introduce yourself as a WCer.
Re: Grinders
Don Leydens
Yea, they do take a little extra time to get up to speed. Robo is probably right about the size thing too. I have a 120 grit, 8" CBN wheel on a Delta 8" grinder and just love it!
See you in Tampa and knock 'em dead in your demo. Say hi to Brenda for me.
