Chainsaw gas ?
Chainsaw gas ?
jim miles
Chainsaw  gas  ?
jim miles
Everybody recommends High octane - 93- No ethanol gas. So it went and found some today. They also had "racing gas"- 100 octane.
Anyone know if this would be good/bad for chainsaw ?
Re: Chainsaw gas ?
Re: Chainsaw  gas  ?
I've been running regular old 87 octane gas with alcohol and oil from my local hardware in my Husquvarnas for 10 years or more with no problems. Maybe they would run better with good gas and better oil but they start first time every time and the only time they have power problems is when the air filter gets dirty.
Re: Chainsaw gas ?
Jesper, Denmark
Re: Chainsaw  gas  ?
Jesper, Denmark
High octane is not necessary if the engine is not specifically designed for it, so any regular gas will do.
Re: Chainsaw gas ?
Re: Chainsaw  gas  ?
Don Orr
My Stihl is recommended to run on 89 octane (one level above regular 87) with the oil mix at 50:1 gas to oil. Higher octane will burn hotter and could severly damage the motor. Most new saws are manufactured to withstand the insult of the ethanol. I have also been using a product called Startron as an additive which is supposed to act as a fuel stabilizer and take care of the ethanol issues. No problems yet.
Re: Chainsaw gas ?
Dick Hines
Re: Chainsaw  gas  ?
Dick Hines
Stihl has a fuel is mix for their power tools but it runs $8 per qt. Now sure how much of it they sell. He did say not to use 87 octane in your saw.
A hint he had was if your saw leaks a some bar oil when it sets is to open the oil cap and let out the pressure build up. It has something to do with the way the position of the oil injector when the saw is turned off. I have started doing this but have not long enough to see if it does and good.
Re: Chainsaw gas ?
Re: Chainsaw  gas  ?
john Veerkamp
Thanks for the tip on releasing oil pressure. I've noticed periodic bar oil in the bottom of my case. Even had the saw checked for leaks, I'll try this fix. BTW I have a 25 yr old Sthil and never used anything other that filling station regular. Always starts and runs as long as I keep a clean air filter.
Re: Chainsaw gas ?
Re: Chainsaw gas
Premium (93) is recommended over regular (87) because it does not cause "preignition" detonations in small, high-rpm engines. It was explained to me that regular is actually more flammable the premium so that it works better in lower compression engines to reduce emissions. Preignition can result in 2-cycle engines that run hotter and faster than 4-strokes and will rob the saw of torque. Both fuels will start the same, but you'll notice the power loss when the chain's running a bit slower and stalling more often.
On the premise that "A lot more is not necessarily better a little more", I'd pass on the racing fuel unless you happen to have a supercharger bolted to your saw. :D
Re: Chainsaw gas ?
Re: Chainsaw  gas  ?
Roger Chandler
My Husqvarna dealer and the Husqvarna website both recommend non-ethanol gas. My dealer is both a Husky and Stihl servicing dealer..........they told me 95% of the issues they have with chainsaws and trimmers is related to ethanol gas........it eats up the rubber parts in time, like the diaphragms in the carb, and the alcohol will separate over time even if you use stabil.
Fresh gas and non ethanol high octane will give you the best power and performance. I have two husky saws .....a 390 XP with 28" bar and a 359 with a 20" bar........plus a 16" poulan pro for limbing.
Your mileage may vary, but I think I will stay with no ethanol as long as possible!
Re: Chainsaw gas ?
Re: Chainsaw  gas  ?
Mike Gibson
Here is the text from the Stihl site
Guidelines for using E10 gasoline in STIHL power equipment:
If the proper precautions are taken, gasoline containing a 10% quantity of ethanol can safely be used in your STIHL products.
Use a minimum of 89 octane gasoline and always use fresh fuel. Only buy enough gasoline that you can easily use up within a two-month period or use a specially formulated fuel mixture like STIHL MotoMix® Premixed Fuel. STIHL MotoMix® is a high-grade, high-octane, ethanol-free premixed fuel containing STIHL HP Ultra synthetic oil. It is a pure and stable fuel mixture that can be stored for up to two years in the original container and is ideal for machines that are used infrequently.
For air-cooled, two-cycle engines, use a quality mix oil that meets the engine manufacturer's recommendations. All STIHL oils are designed to readily mix with gasoline containing 10% ethanol.
