Bowl Lathe
Bowl Lathe
Bowl Lathe
Bob Anthony
Hi Everyone,
Looking for a Bowl Lathe that will turn large Bowls, or someone who will make the lathe for me. Please advise if you have any info on this.thanks everyone
Bob
robanthony101@yahoo.com
Re: Bowl Lathe
How large is large?
David Walser
Bob,
It might help if you were to say how large are the bowls you'd like to turn on your bowl lathe. A Robust American Beauty lathe will turn up to 60" (outboard). A Serious Wood Lathe will turn over 80" (again, outboard). Many would say these are large bowls. You might not.
Re: Bowl Lathe
Re: How large is large?
Bob Anthony
Thanks for reminding me, about 30 inches and less...
thanks again
Re: Bowl Lathe
My Stubby 750 swings 30" inboard .......
JamieDonaldson
without any problem or modifications, and the Stubby 1000 swings even larger.
Re: Bowl Lathe
PM 3520 with outboard - least expensive option
Craig Daymon
It's a good, solid lathe. Add the 18" extension, mounted down low on the leg and get it with the outboard banjo and you're set. The 2HP motor might wheeze a bit turning the bowl, but it can probably handle it if you're not doing production runs of these.
The Robust Sweet 16 with the bed section removed would do it too and might be available with 3HP. Depth of the bowl might be limited in that design.
I'd probably be looking at the Robust American Beauty with outboard riggings. I think it's a similar arrangement to the 3520 outboard setup. Bit beefier lathe.
Then again, PM also has the 4224, again requiring outboard accessories.
-Craig
Re: Bowl Lathe
The Vega bowl lathes is a good option and usually a little less expensive than some. I haven't priced on in a while however.
Re: Bowl Lathe
Malcolm Ray
Malcolm Ray
24" over the bed and 88" outboard on the One Way if you only want to buy one lathe for the rest of your life...otherwise the Powermatic is a good lathe that can handle it.......
Re: Bowl Lathe
Re: Bowl Lathe
Keith Newton
I have a monumental casting which was part of the old railroad shop lathe, from early in the last century. It weighs about 600# I think, and was for the tailstock. I used the headstock for mine, but the bore for this is 5", which is the OD for standard bearings with a 2" ID.
I also have a good friend with a machine shop, who can make anything needed, like the spindle. Together, we could build a mighty fine faceplate lathe, for someone. Your profile doesn't show anything, so if you are just getting started, I would recommend that you find something already in production. I would like to save this one for someone who is showing lots of talent with a long career ahead.
Re: Bowl Lathe
Brad Vietje
Re: PM 3520 with outboard - least expensive option
Brad Vietje
I'd agree.
The 2 hp motor in a 3520-B will have plenty of power if you're not really hogging the wood out. A good friend in NH has made many bowls in the 24" - 30" range, and some up to 48" and even 60" with very thick rims to allow deep carving off the lathe, and all with a 1.5 hp motor on a home-made bowl lathe. Sharp tools, moderate cuts, and a little patience can work wonders.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Bowl Lathe
Dick Coers
At 60" with a 1.5hp, he is a much more patient man that I. I would want to sit down with the size of cut he must be getting. Roughing out at that diameter must be painfully slow. 24" on my 2 hp Oneway will result in stalls. If I was building something for 60" diameter, it would have 5hp minimum.
Re: Bowl Lathe
Harry Robinette
Re: Bowl Lathe
Harry Robinette
I've been using my Vega 2600 for about 10 years it was still called a 2400 when I got mine ( they were being measured over the banjo then) but I really like it. I turn 20 to 25" bowl's on it and I do stall the belts but not the 2hp motor. I bought it because I wanted a bowl lathe but also wanted a tail stock at a realistic price. My Vega was right at $2200.00 delivered through Woodcraft of Cleveland Oh. Besides having a tail stock it has a very small footprint and I really needed that it's like 28" x 19" really small for a 26" lathe.
