Jet Vortex Cone *LINK*
Anybody built one of these to add to their machine. Doesn't look like it would be too hard to do.
http://www.youtube.com/watch?v=4MflPI5K2g4
another link *LINK*
http://www.popularwoodworking.com/tools/jets-vortex-dust-collector
Re: another link
Jeff Smith
John: I spent a whopping $30 or so about 3 years ago on one of those separator lids that fit on a garbage can and added it to my hopelessly underpowered DC (it was about 650 CFM). I have not had to empty the DC collection bag since, and it increased the performance of that poor little thing to the point where it was actually functional. I recently upgraded to a 2HP HF DC that I found on CL, added a Wynn Environmental cannister and kept the garbage can inline. Amazing performance boost, plus, it's easier to empty than fooling with the plastic bags. The whole shebang cost me about half of what a new system runs. According to the online reviews on various forums, the HF 2HP DC is about the only piece of equipment they sell that gets pretty much universal good reviews on.
To quote Willy Nelson's character in The Electric Horseman - it'll "suck the chrome off a bumper hitch".
Re: Jet Vortex Cone
Josh Bowman
Just adding to the mix, a couple of years ago, I pulled my motor/fan off my 2hp grizzly and put it in the attic of my shop, I now just blow the dust, chips and dirt outside via a pipe into a garden wagon. Living in the country, it's out or sight and it it overflows the wagon, it's mulch. Suction is now the same a craftsman shop vac and the efficiency is well, 100%, since there are no more filters.
Re: Jet Vortex Cone
robo hippy
I have also heard it called a 'Thein' baffle. Not really a new thing. This type of set up works fine as long as nothing else goes through the DC other than small shavings. The 2 stage with a cyclone is a whole lot better. Main reason is that anything that goes through the hose, first goes through the impeller blades. Most of them also have a cross hair at the intake to prevent any big objects going into the blades. So, they cross hairs clog up. I had an old Woodtec collector years ago, and had to continually unclog the blades, and had to bend them straight several times from small blocks of wood and rags bending the blades. Yes, it works, but it can be better.
robo hippy
Re: Jet Vortex Cone
Paul
http://www.popularwoodworking.com/tools/shop-made-vortex-dust-collector-woks-on
I made this modification and it works wonders.
Re: Jet Vortex Cone
Jim DeLaney, Austintown, Ohio
I did that one, too. Got the wok at Ikea for under five bucks.
Re: Jet Vortex Cone
Thought about doing one of those, but with the 7' filter bag (rather than the cartridge thing) I don't see much benefit. I use heavy plastic bags for collection , and can see that I've got high-speed circular rotation during operation.
Re: Jet Vortex Cone
Dennis in Southern Oregon
I built a cyclone separator and cartridge filter system using plans down-loaded from Wood Magazine several years ago. The separator works like magic; it separates out ten gallons of chips and dust, while passing probably less that an ounce of dust to the cartridge filter. The materials for the cyclone separator itself consisted of a sheet of 3/4" plywood a small roll of sheet steel roof flashing and a few bolts and pop rivets, and probably cost less than $50.00.
Dennis
Re: another link
Jeff I have the plastic attachment for a garbage can. It does eliminate emptying the main bag nearly as often however it reduces the airflow through the line considerably. I attached the hose directly to my lathe and bypass the garbage can thingy. It simply has more power that way. Works OK for the table saw and bandsaw, and jointer. My planer has a fan that blows the shavings down the hose so it works well with it also.
Since I don't cook that's a good use for a WOK
Re: Jet Vortex Cone
Alan Zenreich
I've built several Thien baffles... they work VERY well (almost nothing gets into the dust collector bag).
Re: Jet Vortex Cone
Tom Henderson, Gulf Breeze Florida
There was an article in Fine Woodworking a couple of issues back that discussed this topic and provide a drawing of a mdf thein baffle. I made one and it works well.
Bought a trash can separator ...
George Taylor
... less things for me to screw up and it is easier to empty than changing the bags.
Re: Jet Vortex Cone
William Duffield
I retrofit a vortex cone to my JDS dust collector. I made it from an IKEA wok, for $5, a few sheet metal screws and a strip of steel. It works well, and is easy to build. You should go look at a JET cyclone at your local Woodcraft or Rockler to know how to bend the steel bar to get the appropriate separation between the cone and the funnel inside the dust collector.
I also have a $30 trash can cyclone separator. It also works well, but you need to use a metal trash can. If you use a Rubbermaid or cheaper trash can and close all the blast gates, it collapses. In the last few years, improvements have been made to the elbow inside the separator. If you have an old one, it has a restriction at the 90° bend inside, due to cheap forms. The new ones are much improved, but if you have an old one, you can remove the restriction and smooth out the air flow with a rasp, files and sand paper. Doing that greatly improves the efficiency of the separator.
Re: Jet Vortex Cone
thanks William I'll check my seperator and see if has any restrictions. I'm headed to Chattanooga this morning for some shopping and will find myself a WOK or something similar that can be modified.
Re: Jet Vortex Cone
William Duffield
The model that used to be carried by Woodcraft was improved a few years ago. Their generic 4" 90° elbow, that is incorporated in the cyclone, was improved at the same time.
http://www.woodcraft.com/product/2004310/8981/trash-can-cyclone-lid.aspx
http://www.woodcraft.com/Product/2000899/9632/4-Elbow-Dust-Extraction-Fitting.aspx
The new models have a smooth bend inside, same diameter all the way through, with a constant wall thickness. The old ones used two inside mold pieces that went straight in and straight out, leaving a sharp 90° turn inside the pipe. They didn't work nearly as well, and used a lot more plastic, so it is good that they have been improved. If you have one of the old ones, and don't feel like rasping out a lot of plastic, just replace the elbow with a newer one.
