SOME of Round & Brown Idea *LINK*
charlie belden
This idea has been floating around in my head for the last few days. I finally created a SketchUp virtual 3D model of the idea so I could get an idea of some of the effects.
Here's the basic idea
The attached link is to a YouTube video of a virtual 3D model of a quick & dirty built Ice Skater.
Ice Skater
Re: SOME of Round & Brown Idea *LINK*
If you made the bowl more of an Ogee shape the skaters arm and leg extremes would flow in a different curve which could add more movement.
Your absolutely right.
charlie belden
John:
An ogee profile would make the cut out shape more flowing - and now that I've got a start on how to "draw" this idea in virtual 3D I'll work on refining the outline so it's less Stick Figurish.
The simple example I did is merely to illustrate an idea. While actually drawing the outline of a figure on the outside of a bowl lets you draw flowing curves and, if done in pencil, to erase and refine the outline. Trying to draw on the outside surface of a virtual 3D model is a bit more difficult because you're working with a mesh surface of small flat planes. That makes "drawing" continous flowing lines acrossed these small flat planes difficult. But I'm working on that.
I started drawing on paper with a pencil when I was probably three or four. By the time I was 12 I'd gotten pretty good at it. This early attempt to draw on a curved Virtual surface is much like what I was doing on a flat surface at 3 or 4. I've learned to learn a lot better in the ensuing years ; )
Seems A Waste of Effort
Going through the whole tuning thing to get what you can far more easily cut from sheet metal and bend to any curve (or compound curve) that you wish seems a waste of time. The idea is about the cut-out shape, not the material, thus the wood and the bowl are unnecessary complications to the production process. Thickness of the material is irrelevant to the idea of the figure so why limit yourself to a rigid material like wood from the profile of a bowl when a malleable material like copper sheet gives you so much more latitude and potential for variation?
cut from flat stock and steam bend
Re: Seems A Waste of Effort
charlie belden
Mark & John:
There are so many ways to do a curved or compound curved shape - as you've pointed out - and provided several means of doing so. If the piece were to be just a sculpture I'd do it in wax and cast it. Wax is so much easier to work with than metal - or wood - and, using an addiitive , rather than a subtractive method (keep adding material 'til it looks like an elephant vs keep removing material 'til it looks like an elephant), is very forgiving. Once I have a wax model I can even electro form over it, melt out the wax and have a very very thin walled, very light, hollow figure. OR -I could do the model in wax, create an RTV mold and cast in in clear or colored resin.
Yes, I could stem bend the piece. But I'd still need a form to bend it on - annd another form - or a bunch of clamps - to keep it there for a while.
But I'm interested in what can be done starting with wood and a lathe - alternatives to Round & Brown - in this case just the Round part. The lathe provides a means to make flowing curves around an axis. I think that is what an ice skater often attempts to do with some of his/her moves as he/she spins - on a single axis. But the human skeleton, even as flexible as it can be, limits continuous sweeping curves.
By constraining the possibilities to a turned bowl I get two things:
- a curved object with more thickness than could be achieved as easily
with sheet metal, the thickness allowing for some additional sculpting
- a narrowing of focus
It's the latter - focus - that I need - to actually get a piece done. With an infinite number of methods, I'd get bogged down in the possibilities and probably never even get to an actual prototype, let alone an actual finished piece.
Actually, Charlie
You've already done the piece . . . in your computer and video. What's next ? ;)
Re: Actually, Charlie
charlie belden
I've done a viritual model and virtually tested some possibilities for how it would create and interact with its shadow. The virtual model is very crude, limited by my current skills drawing on a virtual curved surface. Doing a few more refined - and hopefully more grace full drawings - on a pieces of quad pad paper - at about the size I think will work, and that I have the wood for and skills to turn it - wpuld be the next step.
If the Maasai Herdsman experience is an indication, it'd probably take three or more tries before I'd get to an Ice Skater I liked. The rejected tries could be used to experiment with carving and different finish ideas.
