Some follow up
Craig Daymon
I want to buff the box, but there is no reason to buff the inside where the flocking will be. The issue is that I created the box with an inset lid and wanted to buff up to the point where the flocking would be applied. I was thinking more about any areas at the transition that would inadvertently get buffed. I guess I can do the outside as I normally would and maybe use a Dremel with a buffing wheel to do the inside area up to the point where the flocking will be applied?
I finished the inside since the flocking instructions indicated that it should be sealed. Probably should have wet sanded the first coat inside to fill the pores, though there's enough finish in there to make it pretty smooth. I'm giving it plenty of air time to dry. The instructions indicate that a smooth surface will give better results.
Thanks,
Craig
P.S. I used carbon paper to mark where the lettering/dedication would go on the inside. I hope the font I used is fancy enough. I received a request that the font be fancy. I'll get some pictures up when it's done.
