I got three chunks of Black Willow a couple of weeks ago. When I picked it up, the arborist said it was very wet. It has been sitting in my garage a couple of weeks now and I am wondering if I should turn it, or do I need to let it dry out? Never turned it before.
I would only let wood dry first if it were cut into spindle blanks for furniture parts, candlesticks, or other spindle projects, etc...
For bowls, boxes, vases, hollow forms and many other forms I would never wait for the wood to dry. I'd rough turn it and either finish it as a green turning, or set it aside after rough-turning when wet to air-dry for finish turning later.
A very good resource is: Turning Green Wood, by Michael O'Donnell, which discusses drying methods, and handling green wood for the best results.
As for Black Willow, I've only turned Weeping Willow, and a smaller species that's more of a shrub, called Bebb Willow. I have found Willow to be OK to turn, but not as much fun to sand. It seems to sort of "harden" during sanding -- perhaps from heat build-up (?), and some of the Weeping Willow seems to dull tools a little quicker than I expected, so it might have small silicate minerals in the wood (?) Being a softer wood it tends to need sharper tools to cut well, so it could be a good indicator that the tools need a little honing or touch-up -- that may be what's up. Seems surprisingly hard when dry, for a wood that seems so soft when wet. Black Willow may be a little different.
