ADVERTISE HERE - FREE TRIAL
Bath Renewal
Bath Renewal
Bath Renewal
Lynn Reedy
I am in the middle of redoing a half bath.
I have removed a commode for a upgraded model.
We were looking a the new type that has two types
of flushes. One a half flush and the other a normal
flush. This new type commode has two buttons on top
of the water tank. Anyone who has upgraded a bath knows
what this is.
My question is "has anyone bought this type commode
and have they experienced any problems and do they believe
there are any savings with it".
Re: Bath Renewal
Don in central washington
Re: Bath Renewal
don in central washington
yes we did! and a ada shower stall same time .
Removed the toilet within a month. it was to awkward to flush from the two top buttons!
old shoulders not able to bend around backwards while on the throne. Replaced with a
full flush conventional handled system and a higher than normal seat at same time for our Older years. We literately threw it out.
Re: Bath Renewal
dual flush toilets
Bill Jacksonville, NC
Depending upon model you get may end up using your toilet brush more. Many brands come with cheap seats, no wax gasket or bowl bolts in the box. So need to buy before leaving store. In store purchase better than ordering. Do read reviews before buying some models come with cheap parts.
American Standard has modified the design some to eliminate solids left behind (H2 Option Dual Flush). This models comes in two heights. in May use slightly more water than other brand dual flush models because uses siphoning 1.6 gal for solids and 1.1 gal for liquids. Most other dual flush designs have bigger bowl traps. You can check home depot for reviews.
Re: Bath Renewal
Re: Bath Renewal
I have been flipping some houses lately and using dual flush toilets. They "sell". Several people have commented favorably and no one has objected. I must admit I had not thought of Don's objection of not being able to flush form the seated position. I have used them a few times as we finished the houses, but they go in near the end, so I don't have a lot of experience. I think I have been standing there watching the action. They work well at least initially.
Re: Bath Renewal
Re: Bath Renewal
ihmserv
from a plumbers perspective, (i.e. my day job)
they are ok in a private residence as long as everyone knows how to use it.
terrible in a commercial application.
people who don't use the right button when flushing solids have a lot of stoppages. some models don't allow use of a closet auger to clear them and have to be pulled to clear.
another note all the models use low water consumption. be careful if you have a long run or old castiron piping. can be a problem where the solids don't get all the way out.
just my opinion,
IAN
Re: Bath Renewal
Harry Robinette
Re: Bath Renewal
Harry Robinette
When we redid our bath we looked at the two flush and found it to have all the problems that everyone said here. We bought an American Standard low flush and it did make a difference in the bill. One thing you must do and it sounds crazy but you need to wax the inside of the toilet about once a year and you wont have any messes. Our's has been in for about 18 months and no messes since we waxed it,you will use the brush more but no were near as much now that it's waxed.
Re: Bath Renewal
Steven Antonucci
with 4 kids in my house, i'll take any flush...
Re: Bath Renewal
Re: Bath Renewal
Low water use dual flush and single flush toilets differ in how they operate. Most dual flush have bigger traps and operate by gravity. Single flush toilets also redesigned traps operate by siphoning. Think because not sure American Standard only maker to offer dual flush with siphoning action.
Look at both types to save on my water bill, but found neither dual flush gravity nor single flush siphoning 1.6 gallon toilets will work in my house. My bathrooms and toilet are a back to back installation. Only manufacturer that will tell you that in their owners manual is TOTO. Looked into buying Toto Aquia one piece dual flush toilet after reading about differences in design and operation.
Besides dual flushing after use and frequent cleaning common complaints for both type toilets. In back to back installation can drain trap in other bathroom or push solids into other bathroom.
Yes, people with back to back toilets still install 1.6 gallon toilets. I did not want to take a risk. Some people complain some do not and others just live with it.
Toto puts this warning in both style toilets:
“Due to the powerful performance of our Cyclone, G-Max, E-Max and Power Gravity flushing systems, they are not specified for back-to-back installations. The only means of installing these toilets in a back-to-back situation is when the toilet drain connections incorporate a WYE fitting. Please contact your builder or contractor prior to this installation.”
While 1.6 gallon toilets may or may not have cheap parts, require frequent cleaning issues or not, because of how they work doubt will have trouble with soil lines whether PVC or cast iron unless already have problems with those line.
Re: Bath Renewal
Re: Bath Renewal
John Stegall
Lyn, I put mine in a year ago and love it. My daughter lived in Europe for ten years and we always wanted one so,we,they became available, in it went. No problems so far. It is an American standard.
Re: Bath Renewal
Re: Bath Renewal
Don Evans
Seen the duals and understand how the buttons work, BUT if you want the best toilet on the market get a Kohler "comfort height" model. They are all basically the same except for outside appearances from one model of them to the others.
They work great, they are single flush using 1.2 gal but they work. The most important difference with these units is the way the very bottom of the bowl is designed.
Lowe's did have them for about $260.00 with ring and the quiet close seat but don't know if they still have any.
I figured out why they had them, these are 1.6 units that Kohler replaced the workings in them to convert them to 1.2. As the bowl had 1.6 stamped on top just behind the seat they could not sell them at regular price, look inside the tank and you see where they blacked out the 1.6 and restamped them as 1.2. No way to change the marking on the bowl part though.
I replaced all in the house with them and really glad I did really like the height of them.
Also if you hold the handle down it will use more water, I'm guessing 1.6 gals then.
Kohler also has a seat that acts as a duvet (sp) may get one some day but you gotta have an AC outlet behind the toilet for it. Warm water and warm air to dry now that is a THRONE!
Don
