Veritas - Innovation in Tools
To much wood
To much wood
Dan Jechura
To much wood
Dan Jechura
So I told my buddy I did not need any more wood because I had too much already. I told him a 2nd time I did not need any more. I even told him a 3rd time........... I'm bring home a truck load of red ceder today. Looks like 6 to 12 inch dia. I've never turn it before. Any hints or problems to watch out for?
P.S.
I told my other buddy the same thing and I have a truck load of Hickory and a truck load of Chinese Elm coming. I do not have any of these and have not turned any yet.
Dan
Re: To much wood
I feel your pain...
David Walser
...It's always hard having too much wood to turn.
Well, in my case, it's a case of not having enough time to turn the little wood I have.
Re: To much wood
Re: I feel your pain...
Darryl
cedar turns easily and is beautiful. If it is green it will be sappy. Chinese elm is terrible to turn so why not send it here and I'll take care of it for you. Again it is a beautiful wood when finished. Turn the Hickory before it dries or it will be like concrete. All three make terrific natural edge bowls.
Re: To much wood
Rob Wallace
I combine both Dan's and David's problems...
Rob Wallace
.... with having "too much wood" and not enough time to turn it all....
Despite this situation, I am going tomorrow morning to pick-up a bunch of freshly cut butternut and some ash as well..... .....the next major problem is where do I put it? (I'll cross that bridge when I get to it!)
I am sure MANY of us here fall into this same scenario.....but like clamps in a woodworking shop, there is no such thing as too much wood....
Rob
Re: To much wood
Re: To much wood
waltben
Cedar does turn well and looks great when finished - BUT it's full of silicon, so you'll be dulling your tools quicker than usual. It's also an oily wood (that nice smell doesn't come free), so either leave it unfinished like cedar paneling, or wipe it a couple times with mineral solvents and finish with wipe on poly. Someone else told you the down side of hickory. I've turned several pieces of it after about a year sitting and it was still OK. Much more and it's like cement.
Re: To much wood
Don Leydens
Re: To much wood
Don Leydens
Hi Dan! As far as cedar goes, it turns great and finishes great with a few things to watch for. Turning a big piece like a large bowl, leave the sides fairly thick as just the vibration of the tools could make it crack (hard to disguise, especially sap wood). Small pieces can be turned pretty thin.
I use Tung oil for finishing, but if you sand quite fine like I do, you can see fingerprints on the wood before the finish even goes on. These spots can be a problem. I put latex gloves on after the final sanding and then apply the finish.
The other comment about turning hickory before it dries is a good one. Sanding your driveway would be easier! ;-)
Re: To much wood
George Taylor
Cedar
George Taylor
I take a different tack with cedar ... I like to finish with a penetrating oil. Visually it is not shiny, but the texture for me is wonderful plus the aroma a cedar is maintained as long as possible.
With the mountain cedar we get down here, cracks & splits are always an issue.
Other turners in the area do not really care for it as much as other woods (like Mesquite, Box Elder, Hackberry, etc...)
George
Re: To much wood
Dan Jechura
Re: Cedar
Dan Jechura
explain penetrating oil? What brand?
Dan
Re: To much wood
Re: To much wood
Emmett Manley, Lakeland, TN
Cedar can be very irritating so try not to breathe the dust. About the only way I can turn cedar is by having a fan blow across the wood. Also, cedar tends to chip so be sure to cut downhill. It is often worth the trouble as mixing the heartwood and sapwood can provide beautiful contrasts and the wood finishes well.
Hickory is one of my favorite woods, especially pignut hickory, but the more common (around West Tennessee) mockernut hickory can be very attractive. Individual trees vary a lot relative to the patterns encountered inside, and even the same tree may vary in different areas. Hickory makes great tool handles and other items where strength is important. Hickory is a very pleasant wood to turn as it is non-irritating and without odor.
