cupcake save
Well sorta. This was the cupcake blank I ruined. I hollowed it, cut it off at both ends and then turned and routed some Cocobolo plugs to go in each end. then I turned the Osage Orange finials. should look real interesting together when the Osage changes to a golden brown.
Randy this is one of my Jigs for holding the router. What I did was make a router sled. When I built it I had the foresight to add different bottoms for routing concave or convex surfaces. I simply remove the bottom and screw the holder onto the 45, 90, radius, or flat base depending on what I need.
Aligning it for the cut is the hard part but I'm working on that.
