Something slipped.
I was making a cupcake out of Osage Orange and something slipped. Bummer. I'm going to just turn another part to go in the theads and see what it looks like. May turn it into a Christmas ornament if I do it right.
Something slipped.
Re: Something slipped.
Dick Hines
John, you have been turning long enough to know that you can't make the inside lar
ger than the out side.
Randy gleckler
John, So do you have several jig/setups for your router, or is that jig setup so you can make it horizontal or vertical? I saved your pic yesterday as I've been wanting to make one of these for a while, so now this new pictures has my interest as well. Thanks
Randy I have jigs for everything. I was over visiting the craft Center and my friend GRaham was teaching wood class when I came in. He introduced me and said this guy has a jig for everything.
No seriously I just redid my router jig so that I can slide it on the table horizontally, vertically or at 45 degrees. I had visions of making the 45 degree one adjustable but didn't.
I used to us the router horizontally with a 90 degree router bit. The bottom of every groove had to be sanded because the center of the bit just doesn't cut cleanly due to both it's geometry and the fact that the center simply doesn't have the surface speed of the outer edges.
It occured to me if I mount the router at 45 degrees and use a straight router bit I would be cutting the 90 degree cut with the outer perifery which of course is moving much faster. It worked like a charm.
then I figured while I was at it why not build one at 90 degrees so I could use some of my metal cutting bits or some of the router bits that cut with the outer edge. Works absolutely perfect except for adjusting the bit height which can be a pain.
Then while I was at it I made another jig that can screw on the bottom of anyone of the others and swivels on a center point for cutting arcs. That's what I used to cut the Walnut mirror that had the red and maple slots in it.
