chocolate chip cupcake
I had fun making this one. I turned the chips out of some ebony that had brown streaks. I soaked the tip in water, put them in the microwave for 45 seconds and then bent the tip by rolling it on the counter top. The icing is modeling paste.
Re: chocolate chip cupcake
Karen F.
That looks good enough to eat! How did you do the bottom half?
Galen Vetterick
Looks like real cupcake paper. Nestles will probably try to get money out of you for copy of their chocolate chips. :D
What are the two woods used for getting your threads cut?
I broke down and ordered the EZ threader from Craig today. I guess it is too early to justify reasoning to Father's Day, my birthday or Christmas present to myself, so maybe just due to lack of self control. That happens too often.
Philip Duffy
cool,very cool, John. Philip
Mike Stafford
Fabulous!
Mike Stafford
John, you do such a good job on your cupcakes. This one is a collector's item. Outstanding!
Karen I use my mini router sitting on a table that fits on my tool rest banjo and an index wheel on the lathe. Similar to how I did the Castle Bowl many years ago. I'm going to do another one this morning so I'll take a photo of the cupcake set up. It's slightly diffferent.
Self control, what's that. :) You can use just about any wood, that's why I spent the money on the Baxter threader in the first place. The woods you need to chase threads are just too expensive and hard to find, especially in Middle Tennessee. On really soft woods you may need to cut the threads a little at a time and apply thin CA between each pass.
there is a catch 22 on our boxes. If you make the boxes end grain so there's little wood movement the threads are weak and can chip out. If you make the boxes side grain the threads are strong but the box moves and now the threads may not fit or will bind ever 180 degrees as you rotate the lid. So I generally live with end grain and use CA. It takes longer and is a hassle but you get a clean strong thread.
Randy gleckler
John, that's one of my favorites. The whole cupcake looks amazing and really like those chocolate chips. Very very cool man. Nice work.
kkruizen
What is the most common theads per inch that you use?
16TPI,
20 is good for smaller things, 12 or 10 for larger. My Baxter threader only has 16 right now. I'm going to spring for the 20 sometime. I don't do very many larger ones at this time. At the piece gets bigger the wood movement becomes more of an issue. The larger threads can be made sloppier (read that as more tolerance to wood movement) than the smaller threads. Also on 20TPI the wood needs to be much harder to take the smaller crisper thread. Even at 16TPI the wood will chip out on softer woods so I have to use thin CA and cut the threads in steps with the CA between each pass.
John, shoot these with a soft focus.........
JamieDonaldson
...filter and nobody will know that they're not edible! :D
Re: John, shoot these with a soft focus.........
Jamie I had a lady over this morning to look at some furniture I was selling and she thought they were real. She came in and said wow you've been baking. I said yes you want one and handed it to her. She held it for a minute and then said, is this real? I also had one with me at the school cafeteria where I worked. I left to go get some desert and one of the guys took it thinking it was real. Only after they started kidding me when I got back did they notice it wasn't real.
