New Shop - Another question
Jim Rutten
The space I have is long and skinny. Is there any advantage to hanging the lights the long and skinny way as opposed to the short way (it is not that short at 12')?
Re: New Shop - Another question
I assume you're hanging fluorescent....
JamieDonaldson
...fixtures for general room lighting, and not asking about individual task lighting? For a space that is 12' wide it really makes little difference how the fixtures are oriented, but parallel with the side walls for general lighting would make more symetrical sense to me. Then add good specific task lights at the individual work station positions.
Betty Scarpino
Re: fluorescent full spectrum....
Betty Scarpino
When I installed lights in my shop, I used full-spectrum fluorescent bulbs. Lovely light! I think the company I got them from was Laveck (sp?) Lighting in Ohio. Ask for Ruth, she may still work there.
Dennis in Southern Oregon
Unless your shop will be heated in the winter, you should consider getting a type of flourescent that will start at low temperatures.
Dennis
There are several daylight/full........
JamieDonaldson
...spectrum choices of fluorescent tubes now readily available from big box stores like Lowes. Their efficiency/output varies when compared to the old standard "cool white" tubes, but for any application when working with colored materials they are essential for rendering accurate colors.
Betty Scarpino
Re: There are several daylight/full........
Betty Scarpino
I've had mine in my shop for almost 13 years with only two bulbs needing replacement. Also, I like buying from smaller suppliers, preferring not to support the "big box" method of enterprise (plus I ordered them without having to drive anywhere).
Jim Rutten
Thanks everyone. Once I get electricity out there I will know what to look for.
Rob Wallace
Use 5,000^K fluorescents for full spectrum
Rob Wallace
I MUCH prefer 5,000^K (or 5,500^K) fluorescent bulbs for better color rendering and a brighter overall shop environment - I have a basement shop so it is a big deal to me - with no windows, ALL of your light is artificially provided by electrical fixtures!
I can't stand the dull, orange/reddish 3,200^K "warm" lights, and "standard cool" lights still don't cut it. I have ALL of my shop lights, as well as task light areas (i.e. over my carving station with track lights and CF spots) fitted with 5,500 K fixtures, and it makes a big difference in reducing eye strain, and when applying dyes and other color to pieces.
There are formulas available on the Internet that help you calculate the needed spacing for providing correct levels of ambient light from fluorescent fixtures; correct spacing helps eliminate dark spots - this is a function on number of lamps/fixture, wattage/light output of each fixture, and mounting height above the ambient environment. Remember also that you don't need to illuminate the tops of cabinets sticking out from the wall, so plan your positions of light fixtures accordingly.
Good Luck!
Rob Wallace
