Embellishments
Embellishments
Embellishments
Don in Central Illinois
I want to add some metal leaves to one of my turnings. My question is, is there any particular metal to use or stay away from. I'm thinking copper but I may want to paint them. Do I have to do anything before I apply paint? Best way to cut copper? Lot's of questions and after hearing some of your answers, it will probably bring more questions. As always, thanks in advance for your help.
Re: Embellishments
Re: Embellishments
Craig Daymon
No personal help here, but there is an article on inlaying silver (and other metals) in the latest issue of Woodturning Design. That's solid metal.
Are you planning on solid or to use metal dust?
-Craig
Re: Embellishments
Re: Embellishments
Actually, I want the metal/painted leaves glued to a painting of the flower stem on the turning.
Re: Embellishments
Re: Embellishments
David Walser
Don - I suggest you consider using metal leaf. Metal leaf (very thin foil sheets) comes in many varieties -- copper, silver, aluminum, brass, gold, etc. The process is fairly simple: You apply sizing (adhesive) to the area you want to leaf. Lay the leaf over the area and daub with a soft bristle brush. The daubing pushes the leaf onto the surface, conforming the metal to the intricate details of the item being leafed. Once you're satisfied with the way the item looks and you've cleared away any excess metal, cover the item with a top coat of lacquer of some other finish.
HTH
Re: Embellishments
Re: Embellishments
Dick Coers
Copper will cost more than steel, but you are able to add patina to the copper. I would use a scroll saw for smooth cuts, maybe sandwiched between 1/8" hardboard for really clean edges. If you want a more sculptured look, consider precious metal clay. It's copper powder in a clay form. Sculpt the clay, then bake it. You can bake it over a form for contoured shape as well. It will also take patina. It also comes in silver, gold, and bronze. I think the bronze is trickier to bake, and of course since you are buying real gold, it's really pricey!
Re: Embellishments
Re: Embellishments
That clay sounds like something I could use, especially since my daughter works in polymar clay. Where can I purchase this?
Re: Embellishments
Re: Embellishments *LINK*
Dick Coers
I don't know of a local suppliers, but here is an online source.
Rio Grande, PMC
Re: Embellishments
Leo Cuellar
Leo Cuellar
Don. here is a link to a book on copper work that you can download for free. It is older but the information is still valid. It will help you decide if it is something you want to add to your repertoire. Tools for chasing & shaping can be made out of all different kinds of things, old screwdrivers, odd bits of tool steel, that old set of carving tools that would never hold an edge, nails...
copper work
Re: Embellishments
Re: Embellishments  LINK
Steve Kniffen
Don,
Craft Supply carries a product called Rub 'n Buff Metallic Finish. I have not used it, but the info on it looks like it might do what you're looking for. Here's a link to the product that's closest to copper: http://www.woodturnerscatalog.com/p/3/-/11/51/-/4711/Rub%2527n-Buff-Metallic-Finish
Re: Embellishments
Re: Embellishments
Thanks all. I think I have enough info. Now if I can get this out of my mind and onto a turning like I envision. If it works, photos to follow.
