cupcake blanks
cupcake blanks
cupcake blanks
I got some new wood to play with for my next batch of cupcakes. Osage Orange for the bottoms and wenge for the muffins. That should be cool together.
Re: cupcake blanks
Brad Vietje
Whazacupcake?
Re: cupcake blanks
Something like this- when I get done
Re: cupcake blanks
Re: cupcake blanks
Ryan
Lots of yummy results on the way!! How do you make the flutes on the bottoms?
Re: cupcake blanks
Re: cupcake blanks
I use a table mounted in my tool post and have the router in a cradle. I use a 90 degree cutter instead of the flat one on this shot. I use the index wheel to give me 36 spaces.
Re: cupcake blanks
Re: cupcake blanks
Jim Breeden
John: I like the love cupcakes. Question: When using osage orange, and not using it for the cupcakes, how does a person maintain the orange color ? I've tried all different finishes, except one I don't know of evidently, to keep the color from changing to a murky brown?
Re: cupcake blanks
Re: cupcake blanks
There is no way I know of short of keeping it out of any UV light. It will change. I find the change nice. It's a sort of Carmel brown and a lighter brown. It won't stay bright yellow very long. I actually set the Osage pieces in my window so they will change, before I sell them. That way I don't have any unsatisfied customers bringing anything back because it changed color.
Re: cupcake blanks
Re: cupcake blanks
Don in Central Illinois
I read, fairly recently, of a turner that rubs on the highest SPF he can get to hinder the UV rays from changing the color of his turning. Haven't tried it and can't remember where I read it. Sucks to get old and forgetful.
Re: cupcake blanks
Re: cupcake blanks
Jim Breeden
Getting "old and forgetful" is not a bad thing. The problem is - we have so much stuff crammed up there, it's sorta difficult to remember where it's all at. :D
Re: cupcake blanks
Brad Vietje
BEAUTY!  How'djaturnthefrosting? ;~)
Re: cupcake blanks
Won't work
I ran a test a few years ago on woods like Osage Orange, Cherry, Box Elder, and Padauk. I tried all sorts of UV sprays and finishes. I used some photo spray designed to make photos non UV sensitive. I used several wipe on UV finishes designed to keep auto finishes safe and I tried a bunch of woodworking finishes with UV in it. When placed in direct sun non of them worked for more than one day. The colors faded badly. Now that is a sort of worse case scenario but I would have thought that at least one of them would have prolonged the finish for a little while.
Oops forgot. One did. Marine Spar Varnish. But it yellows and darkens the appearance of the wood so much we couldn't use for anything but boat protection.
There may be more finishes out there. I only tried about 6 or 7 but they were rated as high UV protection.
Re: cupcake blanks
Re: Won't work
Jim Breeden
One of the finishes I tried was Krylon UV Inhibitor, on a Box Elder bowl with Crystal Clear wax over that. The bowl has never been exposed to the sun - but - I can see the red color is not as bright as when originally finished. It's difficult to turn something with bright color, and then see it fade into oblivion.
Re: cupcake blanks
Re: Won't work
Jim If you keep them indoors out of direct sunlight they last a long time. I have a box elder vessel I turned about 7 years ago and it still looks pretty good. I can't say for sure if the color is as bright as it was on day one. What it does is slowly turn toward the greenish brown color that is often on the edges of the red.
My tests were extreme, direct sun for about 14 hours a day. It didn't take more than 2 days for any of the woods to change dramatically no matter what finish I put on it. Krylon UV was one of them along with Armorall, and several other high UV finishes.
I have a friend doing tests on Box Elder right now. He thinks it's exposure to air or pollutants that causes the change but I don't think so because the finishes I tried all sealed the wood really good.
Re: cupcake blanks
Re: Won't work
Jim Breeden
John: It's frustrating is all. I sold the elder bowl to a nice young lady, and told her about keeping it out of direct sunlight, and if it did turn to please return to me and I would refinish it. If I can figure out - AGAIN - how to send a photo I will ( I do have the instructions Ellis sent me).
Re: cupcake blanks
Help it along
Bill Howatt
Some people in our club have gone over the red with a marking pen following the original shape before applying finish.
Bill
Re: cupcake blanks
Binh Pho Airbrushes the color
