Large Elm Vase
Large Elm Vase
Large Elm Vase
Roger Chandler
This is a form I wanted to put on a piece of wood to see how if it turned out the way I envisioned......although I like it, on another I would make a couple of small changes.......
This elm is very ring porous, and tear out of the end grain was a big problem, even with very sharp tools ........it took a lot of wet sanding to get it to this point and I still have some finish work to do on it.......some wet sanding of the finish when it cures and reapplication of a few more coats of Woodturners Finish.
This is nearly a foot tall and is 7.5 inches wide. The second pic is with a box I made for our club challenge which I already posted, but to show scale.
Re: Large Elm Vase
Brad Vietje
Re: Large Elm Vase
Brad Vietje
Looks very nice, Roger!
Is this American Elm, or another variety?
I have not had much end grain trouble with the local Am. Elm I've turned, but I have not used other varieties. I have found that most wood turns well when green or dry, but some are just no fun when in-between. I can't explain that, but kinda-sorta dry-ish wood seems to have the worst of both with the best of neither.
Could you have some not-so-green or not quite dry Elm to play with?
Safe spinning,
Brad Vietje
Newbury, VT
Re: Large Elm Vase
Re: Large Elm Vase
Bernie Weishapl
Beautiful Roger.
Re: Large Elm Vase
Dale Jablonski
Re: Large Elm Vase
Dale Jablonski
Beautiful form, nice job!
Re: Large Elm Vase
Re: Large Elm Vase
Roger Chandler
Yep.......I think the elm was dry-ish.......I know this because during the turning the form moved on me some..........so it had to have some moisture in it.
Re: Large Elm Vase
Re: Large Elm Vase
Roger Chandler
Thanks!
Re: Large Elm Vase
George Taylor
Osage Orange?
George Taylor
From the pic and grain pattern, it sure looks like the Osage Orange I turn ... which can be tough to turn at times.
Just my 2 cents.
Re: Large Elm Vase
Re: Osage Orange?
Roger Chandler
no........this is definitely Elm!
