Grinding a parting tool
Jack Guzman from Maine
I just derusted a nice old tenon sizing tool. The parting chisel that came with it has some pitting so I have to grind it back and reshape the point. I was wondering what would be the ideal shape for this chisel. It is a flat sided 1/4" thick piece of steel.The edge is now shaped like a spear with both edges ground in an arc meeting in the middle. Should I reproduce that shape or is a flat bevel a better shape?I'm thinking,this tool in use doesn't have the bevel resting on the work.On ly the very edge comes in contact with the work so what I really need is just a straight sharp edge but I'm only guessing here. So any input would be helpful.
---Jack
Re: Grinding a parting tool
Robert
The bevel is very important on a parting tool. If you are not going to utilize the bevel you end up scraping. Scraping may be preferred if you want to start a well defined sharp edged groove on the surface. When using the parting tool to reduce the diameter, riding the bevel will allow for a very clean cut. Cutting is done well above center with the tip of the tool following an arcing path from 10 o'clock to the center. Both scraping and cutting are best done with a sharp tool.
Look  In
The "tool grinds" gallery under "odds 'n' ends" on the left side of your screen. Scroll down to where Ellsworth shows a parting tool with 1/2 ground to a convex shape and the other half concave. The tool is used with the concave surface up. The convex "bevel" provides more support for the cutting edge.
I guess this would be a scraping action. I do most of the work with a roughing gouge followed by a skew. The main purpose of the sizing tool is to zero in on the exact diameter of the tenon removing very little material.---Jack
Re: Look  In
I've been hanging out at woodcentral for a long time and I never knew that was there. thanks---Jack
Re: Look  In
I tried Ellsworths grind. I didn't see any advantage and the V shaped grind for me is easier to sharpen. Of course I don't have the years David has with that tool. I don't think the V needs to be flat, I just put it on the grinder and if my wheel is 8" I get that arc, if it's worn down to 6 I get that arc. It doesn't seem to matter.
To use the tool as a sizing tool I still prefer to rub the bevel. you have so much more control. Just put the tool on the bevel and lift the handle until you get a cut. If you stop lifting the handle it stops cutting so you can really sneak up on a size.
Re: Look  In
That makes sense. I often see this curved grind on flea market parting tools. It is a hard shape to keep consistent. thanks---Jack
