How about the other size problem as we age, small. No not that size problem. Well actually small isn't the problem. I had the lower optics on my glasses ground for the proper distance for my detail turning and carving distances. The upper of course is set for distance. Now I have a problem with things that are 3 to 5 feet away. Bummer. Hate to have my glasses look like the way I used to sharpen my gouges (many facets) I tried no line lenses years ago and simply could not use them. Maybe it's time to try again.
On the plus side, working small means I can turn until I'm too feeble to pick up the tools.
You are only in your sixties, too soon to think small. To me dealing with big mother chunks is a way to keep me slim and trim.
On the last of my seventies, I still rather turn a chunk of wood up to 16" across than anything else. A great incentive besides the cardiovascular and fit benefits is that 14" bowls are my perennial best seller followed by 16" platters.
The 14" go for an average of $175. I have a lot of trouble selling a 6" for $30, so why make them?
I need bifocals, but haven't got them yet. I have the magnifiers on my safety glasses. After using them a while, I kept thinking it would be nice to have the magnifiers at the top, rather than the bottom. Spoke to an eyeglass sales person and they said that is possible. (They had a name for it as this configuration is popular for a certain occupation, which I don't recall.) I believe it is possible to have one on the top, one on the bottom and your distance prescript in the middle. Maybe get the lathe work setting up top, the 3-5 foot setting on bottom and keep your distance setting in the middle? Don't know what they would charge for them though.
I had trouble working on my car and also driving nails. They are ground with a bifocal on top as well as the bottom. They were insanely expensive. They are nice. I got to where I couldn't work on the car because you could never have your bifocals on the right spot and your often limited as to where you can put your head. Especially working under the dash sometimes upside down in the seat.
I really like them when driving nails over head. You don't have to crain your neck out of whack.
I tried the variable lenses and they drove me crazy. My peripheral vision is so good I needed the wider field of vision. The standard trifocals can be made with a wider corrected focal area. Bottom for reading close up, middle for computer length, and top for distance. I've had them for 10+ years and like them. Can't say I like wearing glasses but they do the best job for what we need to do. The lines are not a vision impairment and they are hardly noticeable to others.
I tried the magnifying safety glasses with OK results until the day I forgot to change my bifocals for my safety glasses. Suddenly I could see what I was doing (I have the reading lens set to arm's length for using with a computer and for car instruments). It was incredible. The next week, I went back to the store and got some bifocal, prescription safety glasses. They are the same prescription I have for my regular glasses. It's amazing how much better I see and I'm sure I have my safety glasses on, too.
Forgive me, John, I am obviously not as mechanically inclined as you are, but you said: "I had trouble working on my car and also driving nails." What are you trying to achieve by driving nails while working on your car--isn't that rather destructive? To say nothing of creating all kinds of possibilities of leaks what with all those fluids everywhere you look (or hammer a nail).
Perhaps it was a vanity thing, didn't want to look like I needed bifocals, I tried a pair of blended lenses. The first time in the shop with them I was joining the edges of a board, making wavey pencil lines down the face to be joined after each pass to see if I'd gotten all of the edge. When the pencil scribbles were all gone I sighted down the edge of the board. It still looked a little curved, and the corners didn't look square.
A machinist square confirmed that the joiner fence was, in fact, 90 degrees to both the infeed and outfeed tables.
Scribbled more pencil marks on the "curved" edge and joined it again 'til the pencil marks were gone. But sighting down the joined edge, it STILL appeared to be slightly curves - and the corners still didn't look square. Yet when I checked it with a trisquare, the corners were, in fact, square. And when I put a known to be straight, straight edge on what appeared to be a curved edge, again, it was in fact straight.
What the hell is going on!?
Eventually I discovered that if my head was tilted left or right, even just a little, straight lines looked curved and square corners didn't look square. This was an inherent problem with blended lenses - at the time - 10 years ago. I'm told this has improved since then. How much improvement I don't know.
With bifocals, or better yet trifocals (regular distance, computer screen distance and read in bed distance), the Curve Distortion goes away.
Blended or not, scratch resistant polycarb lenses, are a good idea. Lighter than glass and impact resistant, poly carb is a must.
While aviator glasses look cool, they're a bit heavy. Go with smaller lenses, that just protect your EYES are a lot lighter. And if you get titanium frames and have them fitted properly
a) you'll forget you're wearing your glasses and fall asleep in bed with them on
b) the frames are practically indestructible (I've laid on them, sat on them and even stepped on them - with no effect. Titanium is amazing.)
c) they won't slip or slide, regardless of how you move your head
Think of what you've got invested in turning stuff. Relatively speaking, paying for really good glasses and a good frame is a minor expense - and a good investment. You can buy new turning stuff. You're eyes, well you only get issued on pair - for a lifetime.
...expensive, and they are photo-gray tempered safety glass. I can't use the lineless jobs either, but the lines disappear after some time with them, except when looking thru my cameras! Since I'm farsighted, I often remove them when working with "optical instruments."
I find one of these helpful when doing delicate things like finials and smaller items.......I don't always use it, but when needed, it comes in really handy!
sorry, the image did not load.....it is a magnifying lamp that I put over my lathe.
In addition to tri-focals, bi-focals and upper bi-focal lenses, I bought several different focal length reading glasses from the drug store. Cheaper than having new glasses for everything.
I have started purchasing my glasses online. Four sets with each prescription change gets to be a bit much. My last order was for computer mid distance and reading, reading, regular distance and reading plus a second regular and reading sunglasses. Total cost after going with the higher priced rims was $156.00 including shipping. I could have gone with the cheaper single vision starting at $6.95. I've used the Zenni for several years now and my optometrist is happy with the quality.
