snipe
brad bransky
Why am I getting edge snipe on passes through my jointer. I can't figure it out.
snipe
brad bransky
Re: snipe
You should post this on the flat side board. If your getting snipe you either have your knives set incorrectly or your outfeed table is out of square. The knives should be perfectly in line with the outfeed table, not to high and certainly parallel. The outfeed table also needs to be perfectly aligned with the infeed table when both are adjusted to the same height.
adjust the infeed table up to the height of the outfeed table. Check that both are parallel and flat. Then place a small straight square board on the outfeed table, I use a 3/4x3/4 by 1 foot. Place a pencil mark on this board about 3" from one end. Place the board over the blade without the blades touching and with the pencil mark aligned with one of the tables. Now rotate the cutter head by hand. When the cutter touches the wood it should either not move it or move it very slightly. Do this on both ends of the cutter. It should move the wood the same amount. If it doesn't the blades aren't parallel with the table. If it moves it too far the blades are too high (which will cause snipe). If it doesn't touch the wood then the blades are too low.
Re: snipe
Brad
Excellent! Thanks John. Sorry for posting on the wrong board but what is the "flat side board" or is it a pun, which if so, is excellent. None the less, I posted on the wrong board, sorry.
Hop-Skip Method
First:
Raise your infeed to the very top then use a good 3' steel straight edge to check the parallelism of the tables (you'll have to remove the shield and rotate the knives out of the way) by moving the edge across the surface checking for any gaps between the rule and the tables. If gaps exist, consult your owner's manual for instructions to adjust the table gibs.
With tables set, drop the infeed table a 1/4" then, instead of John's wood, use a 1' rule from a combo-square.
To test the knife height, set the 2" mark at the edge of the outfeed table and rotate the head so the knife catches the rule and moves it; should be no more than 3/32". Do this for each knife at each end of the cutter head.
Adjust the knives with the jacking screws.
Re: snipe
Jim Breeden
You need a "snipe" dog
to run 'em down.
Re: snipe
Bob Lalonde
Hi Brad. Even when my jointer is perfectly adjusted, I get snipe when I forget to ease off the pressure on the infeed side as I near the end of the cut. I need to make sure that there is even pressure on both side of the knives.
Bob.
Correction
The steel rule should not move more than 1/16" preferably less.
Checked my set-up specs rather than from memory.
Re: snipe
Brad
I think you've got it. I think I continue the pressure all the way through the cut and that's probably the problem. I'll try it in the morning. It's 0024 here and I'm in bed watching "Gangster Squad". Thanks Bob.
Bradkansas
