vacuum chuck
vacuum chuck
vacuum chuck
Don in Central Illinois
I may have the chance to buy a used pump. My question, what is a minimum cfm for a vacuum system? All help appreciated.
Re: vacuum chuck
Re: vacuum chuck
Doc Green
Hey Don,
I don't think there is an established minimum for the cfm rating, but with lower values you have to have a tighter system in order to get sufficient vacuum at the chuck to do the job.
What I think I know is that 3 or 4 cfm will do fine. This is enough capacity to overcome considerable leakage around the seal of the chuck and through the coupler.
A friend of mine has a really small vacuum pump, hardly bigger than 1/3 a loaf of sliced bread. It's old and beat up; origin, make, model unknown. My guess is that it's rated at 1 cfm or less, if even that much.
It would not provide a usable vacuum (maybe 5" Hg) through a typical shop-made coupler with a single, double-sealed bearing. My comment was that he didn't have much of a pump. However, when he switched to a store-bought coupler with two bearings, the vacuum reached about 15" Hg, which is enough to be useful. He thinks it's great!
The bottom line is, you can use a pump with a low cfm rating (around 1 or 2), but you will have to be more careful about leakage around the seals, through the wood (yes), and so forth.
An obvious tip: be sure to include a reliable, easy to read vacuum gauge in your system.
Good luck. ~Doc
Re: vacuum chuck
Re: vacuum chuck
Thanks, now to see if it's still available.
Re: vacuum chuck
Re: vacuum chuck
Don There are many articles in past journals. If your an AAW member go online and look them up. I think I remember reading the 3 to 4 CFM as Doc said is good. The articles also cover setting them up and making the chucks themselves so it is worth reading through them.
Re: vacuum chuck
Re: vacuum chuck
I very seldom use my vacuum chuck but I have one of the small Gast pumps and I think its about 1 to 1.25 CFM and it works OK. I would be less nervous with a higher volume pump, but I have not had a problem I can associate with the pump.
I use the same pump for a veneer bag press. (Somebody help me with the name of this. Please.) It works fine on small stuff and holds the vacuum well once it have sucked the air out of the bag.
The Joe Woodworker site has lots of useful info. JoeWoodworker.com I think.
Re: vacuum chuck
Re: vacuum chuck
I'll look them up this weekend. Thanks.
Re: vacuum chuck
Not much on vacuum chucks....
A lot on vacuum pumps and ideas. The idea of a reservoir might be a good one.
Re: vacuum chuck
Re: vacuum chuck
Pete in Holland, MI
http://www.grainger.com/Grainger/GAST-Vacuum-Pump-4F742?Pid=search
Here's mine. 3/4 hp. How are you measuring CFM? Depends on which pressure you're measuring at.
My pump was picked up used for $60.
If you vacuum system is perfect, you don't need much CFM. The larger pump you have allow for some of your plumbing.
You also need to consider porocity of your wood. If your wood is very porus, you need a much bigger pump. You'll know this when you rub your hand over your bowl and is "feels sticky". This is the leaks in the wood sucking on your skin. Some quick coarse sanding often clogs the pores and makes for an acceptable vacuum.
Always have a vacuum gauge (as large as you can get for better visibility) in plane sight to keep an eye on what vacuum you are maintaining, else your bowl might "sprout wings" without warning.
Pete
Re: vacuum chuck
Re: vacuum chuck
Stuart Johnson
I don't think it will work on a bowl but I've had good luck wrapping hollow forms and vases with clear plastic shipping wrap. The stuff stretches and clings to itself similar to thick kitchen wrap which would probably also work.
Re: vacuum chuck
Dick Hines
Re: vacuum chuck
Dick Hines
If your chuck is leaking vacuum just find the "sticky" places and place masking take over them. You can see the vacuum move up with each piece of tape.
