How thin to turn a lid
I think I got this one a little too thin. It was fine until I hit it lightly with 220 grit sandpaper. Then I heard something funny and saw a streak of color. Bummer. Oh well. I also didn't wax the mating surfaces of the lid and body and can't unscrew it so even if I had not gone through the lid it might be a loss. Normally on these screw lid boxes I wax the threads and mating surfaces to make them screw on easier and screw off easier. This one might as well be glued in place.
Re: How thin to turn a lid
Mike Stafford
I have never turned a lid or a body too thin....
Mike Stafford
since the last time I did it which was probably in March when I trashed a beautiful piece of mesquite by making the inside and outside diameters of the body of a box the same.
Re: How to turn a lid
How do you "fix" your lid to hollow it?
I've taken to using a jamb chuck and hot-melt glue and this makes it pretty easy to avoid your kind of casualty. I put tape and 2 marked rings on the outside of the chuck representing the center and the hidden part of the lid profile. I can then use my laser to accurately gauge the lid's thickness. Haven't gone through one yet (since using this method ;) )
Steven Antonucci
More hollow than solid.
steven antonucci
Inside> outside
Zero thickness.
I crush these so I don't get tempted to fix them or spend a lot of time thinking about fixing them. Usually, as it happens, with the lathe still spinning and a quick strike of the handle of whatever is closest. While voicing profanity.
Be done with it.
Steve
Mike Stafford
Mike Stafford
When I turn a box I turn a tenon/spigot on each end of the blank. Then I part the blank into two pieces determining where to part based upon the design proportions I am aiming for on a particular box.
Then I chuck up the lid by the tenon/spigot and hollow and shape the underside of the lid forming square shoulders for the lid to overfit a tenon on the body of the box.
When all this is done I carefully mark the depth of the hollowing in the underside of the lid on the exterior of the lid blank and use that to gauge thickness when I jam fit the lid on the body for finish turning.
I don't usually have lid problems unless there is an unseen crack or something. I tend to get carried away while hollowing the body and make it too thin.
Mark I hollow the lid before installing it on the box. Then I turn the lid and box together. I can't ever remember that I have done this before. It was actually just a practice piece testing a new threading machine and the top was thinner than usual. I didn't think it was that thin however. I would have been OK but in rushing the box I made a force cut across the top and left a tiny bit of tearout. I made 2 more shallow passes to remove the tearout and that was probably my error.
Me neither
Dale Miner
I have a wood stove though and sometimes practice on the wood before tossing it in. :D
Bob Macgregor
Well, how else were you going to get into the box if the threads were jammed?
Exactly Bob and saves on Glue
robo hippy
Keep it on the lathe and hollow out a contrasting plug for it. Might be difficult to turn out the inside again.
Which threading jig do you have?
robo hippy
I use the Baxter Jig and highly recommend it
I was sent a much less expensive unit to test and I'm still playing with it. It needs some improvements both in the unit and the literature. I will be passing my suggestions on to the maker. I think it has possibilities. It will never be a BAxter threader but it's like driving a Ford vs A Mercedese. You can have a tool that will get the job done with some limitations and maybe not as accurately or you can have a real precision instrument. You of course pay for the precision, so there is a place for this tool if they work out some bugs.
