Mahoney Walnut Oil Wax Finish
Mike Stafford
Mike Stafford
I bought a tub of Mahoney Walnut Oil Wax Finish last fall and used it on a few pieces.
Today I grabbed it from my cabinet and when I opened it the wax finish had turned into something sticky and gummy like chewing gum. It as so sticky I could not get any out of the tub on a rag. I know the lid was on tight so there was no air leakage. I tried digging the really stick stuff on the top out but the finish under it was just as bad.
Is this normal for this finish? Does it have a very short pot life after it is initially opened?
Not at all happy to see this go bad after a few uses and less than 6 months.
Re: Mahoney Walnut Oil Wax Finish
Dale Gillaspy
I don't think so. I have had a bottle for several years and it is still like new. You might try contacting the place you bought it, or contacting Mike directly. Try www.bowlmakerinc.com
Yea my finish is about a year or more old and still good. I've used about 1/3 of the bottle.
Mike Stafford
Not talking about the utility oil finish....
Mike Stafford
I am talking about the wax finish in the small plastic tub.
The oil finish seems to be okay but the wax finish is a gummy sticky mess.
George Taylor
My wax looks OK ...
George Taylor
Just went into the garage and checked my jar of Mahoney's wax and it looks OK ... had it for at least a year (used sparingly). Stays in un-air conditioned space.
I could use some remedial box making lessons however :D
I have some of Mike's Oil/Wax from....
Greg Haugen
.....'05 when I bought it and a bowl from Mike. It's been used about once every 6 months roughly and is still good. Just checked it and freshened up the bowl tonight. No issues here.
Mike Stafford
Mike Stafford
Well, I can tell you this the plastic tub I have contains an unusable sticky gummy mass that cannot be spread or used on anything. It resembles chewing gum more than wax.
I won't be spending $15 for another tub.
John Veerkamp
Contact Mike, He'll want to know about the problem,
Mike Mahoney
Hi Mike
Sorry your jar went bad. My wax usually has a 3 year shelf life. I will gladly send you another. Mike
Mike Stafford
Mike Stafford
Mike, what do you think happened? This stuff went from creamy when I last used it to sticky, gummy like bubble gum on a hot parking lot. When I tried to use it, it formed strands of sticky stuff that snapped like rubber bands when I was pulling it out of the tub.
It even changed color.
Very strange. Too cold, too hot?
