Something to think about...
bmckearney
I picked up the latest copy of Fine Woodworking magazine (June 2013 - #233) and the article about a "Unique Cutting Board" caught my eye. In case you haven't seen it yet, Scott Lewis essentially cuts a curve in the board and then glues it back together by sandwiching a thin piece of contrasting wood. If you keep doing this, you get some really cool patterns.
As I was thinking about this, I wondered if this could be applied to woodturning. Could make some really cool bowls or hollow vessels. I don't really have the time right now to play, but thought that others may benefit and I'd love to see the results.
See more here: http://www.finewoodworking.com/how-to/video/the-coolest-cutting-board-ever.aspx
Brian
Re: Something to think about...
George Taylor
George Taylor
Check out the work of Virginia Dotson or Jim McPhail for a couple artists who work with laminations.
That is essentially what I have been doing with my Fan mirrors. I did some many years ago where I cut from several directions. You'll notice he used a jig to route the edges true. I found that if you cut 2 curves such as a S and add very much thickness in the veneer they will not fit together straight off the saw (I used a scroll saw that leaves a clean cut that didn't need sanding). If you want to make more complicated mating arcs like he did then the jigs are essential.
Pretty cool article and a great job on the cutting boards.
Can it be done on larger scale such as bowls.  *LINK*
Yes Look at John Beaver's work. I have a hollow vessel right now that is waiting for a test. It was a blank that started to crack. I put my froe in the crack and split it open end for end. Then glued it back together with colored epoxy using some tooth picks as spacers. When it was dry I turned the outside and then put it up. I forgot about it and just found it this weekend. Maybe I'll have time to follow up on hollowing it out pretty soon.
The epoxy will fill in the space so the 2 mating parts don't have to be a perfect fit like in his article.
http://www.bing.com/images/search?q=John+Beaver+Woodturner&id=D1A77BE4B414466812F0A89DDBD182FEEFF4BBD8&FORM=IQFRBA
Re: Can it be done on larger scale such as bowls.
Joe Herrmann
Yes, it works quite well for larger forms. There was a Fine Woodworking article many years back that detailed one of the techniques for cutting a blank and then gluing in a thin strip of contrasting wood. When I was teaching the Kids used to do them. There was also a method of making a scene by stack cutting several different piece of wood. We used to make mountain scenes with the sun peeking out over a hill. I can't recall where the directions came from though. We used to make serving trays using the technique. Both produced some interesting work. I should resurrect the process...
bmckearney
As I wrote that post this morning, I thought of your mirrors, John. Looks like you're light years ahead of me. :) Cool stuff!
