Where to get velcro backed sheets of sandpaper?
steven antonucci
any ideas? I want to cut my own discs...
Steve
steven antonucci
Steve
Re: Where to get velcro backed sheets of sandpaper
Alan Zenreich
You might also try some Abranet... it's loop backed. It's not conventional sandpaper, but it's my go-to abrasive.
Re: Where to get velcro backed sheets of sandpaper *LINK*
Stuart Johnson
I've purchased from these folks.
Industrial Abrasives
Harry Robinette
I believe Klingspor has it.
Darryl
ditto I/A. sells 1 meter sheets of extremely good stuff. I used a sharpened 3" and 2" hole saw in my drill press. works well but I switched to Vince after a couple of sheets of the stuff. I believe the stuff is "Rhyno" backed or some such name. A meter in the various grits lasts a bunch of time. Darryl
Vincent Welch
Hi Steve,
If you want reach out to me and I will see about getting you some sheets so you can cut your own shapes.
Vince
robo hippy
I went the punch my own route for a while, and even had access to a table top hydraulic press, which would punch through 5 layers at a time. With the cost of Vince's discs, it just wasn't worth the effort, especially if you are short on time in the shop. The quality of the abrasives from Vince are better as well.
robo hippy
Terry Scott
Steve I use the Japanese paper called Astra dot by Buffalo
Bill Neddow did a test last year and proclaimed it as being one of the best papers he had used along with Ice
It comes Into the country in 50m x 1.120m rolls but it is manly sold to wood turners in 1120 long and 15mm wide Also comes pre- punched but it works out a bit expensive .So Ive had a hole pile of stainless tube cut so that turners can make up a 2 inch and 3 inch punch
Easy to make see here all you need is some heavy wall tube
http://www.timberlywoodturning.co.nz/products/Timberly-Sanding-Disc-Punch-Kit-.html
Usually punching your own is fin for the average hobbie turner as time is not important
I have to admit I use pre punched as I can buy in at 100 of each grit at a time which lasts me a while
You do tend to waste a bit more pre punched as its handy
Cheers
Mike Stafford
Several years ago a bunch of us went in together and bought large sections of sheets of hook and loop paper. It came in a metric width which was not a problem but some forethought was required when cutting discs to best use the paper.
It was a whole lot of work making your own discs and I finally just cut the paper up into appropriately sized squares and found that they worked as well as the disc shape.
I cannot remember from what company we bought this paper. I did it one time and don't believe it is worth the effort.
Industrial Abrasives.
