I seem to have lost my Skew Mojo
charlie belden
The straight edged skew was the scariest turning tool I had. Then a kind, very experienced turner, showed me how to put a curve in the cutting edge. From that point on, the skew became my favorite tool and I've used it a LOT, often for making cuts it probably wasn't intended to be used for - but it would.
Today I was using it to round off the top of the head of Stylized Masai #3, in maple, a normally very friendly turning wood, and my skew just wouldn't behave. Making rolling cuts I've made thousands of times before, it'd bounce and chatter and didn't seem to want to cut. I checked the wood - no knots, no pitch pockets, no cracks or splits, no squirrely grain. I sharpened the skew and honed it - and it still wouldn't behave. Adjusted the tool rest up and down - to no avail. I normally start a skew cut with the long point, but when that didn't work, tried starting the cut with the heel. No luck, still got chatter and a tool that wouldn't cut cleanly. Tried starting the cut with the middle third of the cutting edge , the Safe Zone, and still got chatter and difficulty cutting wood. Even resorted to sanding the area smooth to get out the little chatter marks the tool was creating. Did no good at all no matter what I did.
So I figured I'd use a 1/4 bench chisel as a bedan - again a tool I've used a lot. It was really sharp and the bevel even polished - but it - like its cousin, or perhaps offspring, chattered and bounced and just wouldn't cut clean.
I seem to have lost my Skew Mojo.
Anyone have a suggestion on how to get it back? I'm, THIS close to finishing the turning of Stylized Masai #3 and I'd like it to leave the lathe for the last time with a nice smooth rounded top of its head. H E L P !
Re: I seem to have lost my Skew Mojo
Don Stephan
Perhaps the surface is out of round, so the tools are bouncing.
John Veerkamp
or some play has developed in your drive?
Think I've Figured It Out
charlie belden
I think I've figured out what was going on.
Since the legs at the "ankle" are 3/16" diameter and the top of the neck is 1/4", I snugged up the tailstock just enough for the spur drive to work. Any more pressure and the piece would flex. What probably happened is that when I applied the skew to the wood, the wood would slip a little as I started the cut. Continued pressure would re-engage the spur drive and the cut would start again. The chattering was probably more like skipping - cut, stop turning, turn, cut . . .
OR
the piece was flexing
Leo Cuellar
Any way to chuck it?
Leo Cuellar
Or are you still off center at this point? If so, perhaps gluing a larger waste block to it for a screw chuck, or maybe a hose clamp around stub to keep it from splitting with a small screw chuck.
robo hippy
I never had any skew mojo to start with. However, a local turner has a 10 to 1 rule for spindles. 10 inches long, 1 inch diameter, means no flex from tool pressure. Your piece has some very thin spots for turning that long. Turn to completion as you move from one end to the other, and NO going back.
robo hippy
charlie belden
This is a multiple axes piece.
The head is triangular, tapering slightly - three intersecting arcs turned on three axes.
The torso is lens shaped, also tapering slightly - two intersecting arcs turned on two axes
The neck, top of head and legs are turned to full round on the blank's center, the neck and legs tapering
The blank is 1 1/2" square
Here are the centers on one end of the blank - which are the same for the other end of the blank. As you can see, the triangular head is turned to the right, relative to the torso and the centers for the torso are offset from the blank's center by about 1/4". It's the torso's arc centers offsets that preclude turning from one end to the other. Were the legs and neck turned to their final smaller diameter first, the piece would probably failed when the torso and head were turned on their offset centers.
The piece required turning on six axes (2 for the torso, 3 for the head, 1 for the neck and legs) - and had to be done sequentially in the following order
1- Turn the torso on its 3 axes to about the desired cross section
2- Turn the bottom of the neck and top of the legs to a diameter slightly smaller than the short axis of the torso lens to get a crisp top and bottom edge of the torso
3- turn the head on each of its three intersecting arcs' centers
4- turn the top of the neck to a diameter slightly smaller than the
the head
4- remove, stand upright and check the vertical proportions
5- repeat the process eight or 10 times to sneak up on the final proportions
The final lengthening and tapering of the legs was done AFTER the torso and head had been turned to their final size. The final turning of the neck was done next to last, the rounding of the top of the head and parting off was done last.
The piece doesn't appear to be that difficult to turn. But because of the offset turning, the long tapering legs and the iterative turning process to get the proportions right - it was a lot trickier to turn.
Terry Scott
get a 6 x 6 post 8 foot log and turn down to a miniature goblet
You will have the mojo back by the end
