Lennox Die Master Bi Metal Blades
robo hippy
I posted this over on SMC, and am curious about the WC people. I have been using these forever (20 plus years). They were recommended to me by a local contractor I had done concrete work for. As near as I can tell, they are the best cutting blades for green wood out on the market, and I am wondering why they are so relatively unknown in the Woodturning world. One turner was having problems with his Timberwolf blade cutting through some Eucalyptus (twisty grain, would not split with wedges and sledge). The TW did fine in most other woods, but wouldn't cut straight in the Eucalyptus. Well, being curious, I sent him a blade in trade for some of the Eucalyptus. It cut the wood straight, and faster than the TW blade.
So, any one else out there use them?
robo hippy
Re: Lennox Die Master Bi Metal Blades
lynn cranmer
Yep, Use them on my 18inch Rikon. I cut a lot of driftwood with embedded sand etc and they last a long time.
Dennis in Southern Oregon
Who sells them?
Dennis
Thanx.
Dennis
Mark Strang
What tooth pattern, width, and TPI are you using?
robo hippy
Mark,
My little saw, 14 inch PM industrial has a 96 x 1/2 inch x .035 x 3 tpi blade on it. It will cut circles just slightly under 6 inches. I prefer the thicker blades. Big saw, a Laguna 16HD with 4.5 hp motor, has a 1 1/4 by teeth at 3/4 inch apart. Perfect for slicing up slabs.
robo hippy
Mark Strang
Thanks. I'm going to have to call them cause after a quick look at their web site , it appears as if I can only get 6tpi for a 105 inch blade. Hopefully, I read it wrong. I use a Timberwolf 3 tpi now with no problem but would like longer life such as you are getting. I do a lot of wet large chunks of various hard and soft woods. I mainly do bowls of a larger size up to 20 inches and the blades when sharp cut nicely, but it doesn't take too long for them to lose their effectiveness.
Mark
Doesn't anyone here sharpen BS blades
barry rockwell
barry rockwell
Dennis and Mark, I have used them for a long time with great success. I have always ordered them from www.bandsawbladesdirect.com/ (also called Action Industrial Supply) and they have always taken very good care of me. I order by phone because they don't have every single item they offer on the web site. I have gotten very good advice from "Jerry" at (231) 722-6711 and currently use a 1/2" x 3TPI Hook Tooth blade for my 14" Rikon. If you tell them that you are in a woodturning club they will usually give you the next step-up price break for the amount you order. Shipping for orders over $100 always free. Good Luck.
I usually get 3 sharpenings before recycling
Dick Coers
I use my Dremel and a flat disc grinding wheel. Just bump the top of the tooth, and it cuts nicely again. I usually get 3 sharpenings before it gets too far off of factory grind. And that is with a silver solder joint that I do myself.
