I Know, I didn't want to highjack the other thread, so here it is. I have a craftsman, oilless, 120v compressor and my problem is that I turn late at night and I live in the suburb and in a cal-de-sac, the darn thing has mind of his own and kicks on when it wants to then sits for a long time. I really need to use it, however, it's loaud and I am affraid that neigbors might hear it and I need to blow my lathe before I retire. Anyone knows of any trick to dampen the noise on this so I can use it even late at night?
Make a box out of 1/2 ply large enough to clear by 6" on all directions (but down ). Line the box with 1/2" Homesote. Staple 2" bat fiberglass insulation to the Homesote with the fluff exposed. Drop the box over the unit leaving 2" of space at the bottom for air circulation.
Should muffle the beastie enough not to have the neighbors walking their dogs on your front lawn.
What Mark suggest will work providing your compressor sets on concrete. If it sets in the rafters or on a joist floor then the vibration exacerbates the noise. It has a mind of its own because you have a leak in the system somewhere. Pressure drops and it kicks on to bring the pressure up. Fill your tank and flip the shut of valve so it won't leak through the air nozzle, hose fittings or wherever it is leaking. It'll stay quite until you need it.
Dale, you are absolutely right about the leak. It does have it and it gets on my nerves when it kicks on even when not in use. Last night it kicked on when I was not even suing it and the blower was sitting on the floor, so I had to run and shut the darn thing off. I am going to test it for leak today to see if there is someway I can stop that.
The only reason it should be turning on is that it's loosing air (slowly) from fittings. Put a ball valve on the output before the first hose fitting, then turn it off at night. Your compressor shouldn't come on anymore unless there's something more serious wrong.
What you could do to really quiet it down is get an oil type two stage. Some of the newer oil-less ones that meet OSHA (I think) noise standards are a lot quieter as well.
Easy to find out...Just dunk the nozzle in a bucket of water. If there are bubbles, that's it.
Way back before tubeless tires, (you young guys don't remember tubes in tires). they dunked a leaking tube in water to find the leak. I've had tubes with umpteen patches before retiring it. When I was a teenager driving a Model A Ford I fixed my own.
He is not kidding. I'm not quite as old as you wally. But I worked at a gas station and fixed tubes on tires and dunked them in water. We would get the tires off with a series of crow bars...careful don't pinch the tube!!
And back in the day when all gas stations also did tire repairs, as kids we'd go to those stations asking if they had any old inner tubes we could use as the firing propellants for our sling shots.
patched'em, and used'em for both river floats [yeah, Wally, down the Salt River ] and snow sleds. The b-a truck tires were premium although you could get ruint on the valve stems because they would carry you and your mesh bag of Hams.
Ever have a B 49 tube? made trampolines, floats for swimming, you name it. anything a kid could think up. Tough enough to survive rocks in fast moving streams or being pulled on icy roads.
The box may help quiet the compressor. The problem is any box that keeps in the sound will also keep in all the heat and oilless compressors live on the very edge thermal failure without the cover.
In the days when kids made their own toys...pre WWII, Innertubes were used for slingshots along with the tongue of an old shoe and a willow fork. We made guns using a sping-loaded clothes pin and an innertube band. Doubled around your leg to keep your pants out of a bicycle chain. As the bungee-cord of the day. And much more. I lived a short distance from a fast river. We would float down the river on an innertube for a mile or so, then carry the tube back and do it again.
A lot of the noise is caused from all that's mentioned and also the air intake. We have 4 huge compressors where I work and we installed mufflers on the intakes and it took a bunch of the noise away. I think I remembers seeing an article somewhere that did the same of a home shop compressor. Anyway, just a thought.
My nephew has a 120 gal LOUD compressor .He put a air line onto the intake with some fittings and it lays on the floor about 8 or 10 foot of hose. It quieted his alot he's looking for a better muffler now.
John, if you have any B49, spare send it my way. I may be able to wrap the darn thing around the compr. few times and stop it from vibration, and maybe loud noise. Sounds, like you guys had fun with those stuff.
Mark, I looked up the insulation then I went to their web site and it says contact a local rep. then he sent me to Houston. Houston distr. said to contact their branch in san Antonio, and round I went until I found out that they don't sell direct to consumer. Now, what you just mentioned is something else. from the Home Depot. I'll look into it.
There are some great plans for an insulated sound deadening yet ventilated compressor box in the Workshop Book by Scott Landis published by Taunton Press.
I am sure you don't need plans but if you do these are highly recommended. The box works!
The problem is that the intake air valves are almost touchable, thus the noise they generate is very crisp. Most have simply a piece of felt as an air filter, and the valves are right behind. If you can enclose that intake system and have it draw from a more distant location, that will cut down noise.
Wanna check? With compressor running, firmly put a pillow over the intake for a few seconds to see what others mean.
Your hose that is used to move the intake away from the compressor head can help too. Make it out of PVC, and the sound echo down the tube. Make it out of rubber, and the rubber will absorb some of the noise. Just make sure to have an adequately large hose, else the compressor will starve for air. Corrigated hose also breaks up sound waves.
Plumbing this hose in a wood box 12 or 18" square, with the insides lined with a fiberglass ceiling tile plus and use this tile to create a couple baffles, and several make-up air holes in the box (don't want to use the fiberglass as a filter) will also absorb the noise.
Question: Have you asked your neighbors if they can hear your compressor ? Way over there, they may not be able to hear it, or it is insignificant. At least, close your garage doors.....all of them.
You could also turn it off about normal bed time, then use the stored air to clean up several hours later.
