YES! With Details
Brad Vietje
Sorry to Chime in so late here...been doing taxes for a few days :~(
Since I operate a small solar installation company, and deal with these small battery-based systems daily, I'll be happy to help anyone who wants to run the numbers -- I won't try to sell you anything.
Simple answer is YES you can charge the battery/batteries with solar panels -- or another charging source if that works better for you. It all boils down to how much power your equipment needs, how long you want to run it, and how quickly you want/need to recharge it. The size of the inverter needed depends on the load, the size of the battery bank depends on how long you want to supply this power, the amount of solar needed depends on how fast you need to replace the power consumed.
Example: Here's one relevant example: my Nova Comet mini with a 1/2 hp motor, consumes about 350 watts. Add a pair of (LED) lights and some headroom, and we could call that 400 watts for a nice round number. Let's say I want to turn for 4 hours a day for a 3 day show; that comes to 12 hours at 400 watts, which comes to 4800 watt-hours, or 4.8 kWh.
Inverter: For a continuous load of ~400 watts, it would work best to have an inverter that can handle at least twice that much, to handle start-up surges. I'd go with a 1000 watt inverter, in this example. Then consider a pure sine wave vs a modified sine wave [sic] inverter (nobody would modify a true sine wave, so that's just a marketing gimmick -- it's really a modified square wave inverter). True sine inverters are MUCH better for anything that's variable speed, and will allow the motor to run more efficiently and run cooler (and use less battery power). For simple capacitor-start motors and most lights, a Pulse-width modulated "sorta-sine" inverter will work fine, and cost a lot less. For variable speed motors, spend the added funds, and get a real sine wave inverter. My Nova Comet has no variable speed, so I'd probably run with the less expensive inverter. A good value is a 1000 watt inverter/charger, which will automatically charge the batteries when plugged into grid power, even if no solar energy is available.
Batteries: If the battery bank needs to supply 4.8 kWh for 3 days (and assuming the worst case of no sunlight to help out), you'd ideally want to only use 50% of the battery capacity to deliver this, so you'd want a 9-10 kW battery bank (or re-think the 3 days of power part!). for a 12-volt system, that means you'd need about 400 Amp-hours of battery storage. That means using 4 big L-16H deep-cycle batteries (~130 pounds each!), which will cost some real money!
SO -- Let's forget 3 days of stored power, and shoot for a single, 4 hour day, instead! 4 Hours x 400 watts = 1600 watt-hours = 1.6 kWh, or 3.2 kWh if we limit the depth of discharge to roughly 50% (for much greater battery life). Using a 12-volt battery, that comes to 267 A-h. You could use 2 group 31 marine batteries in parallel, and since these are sometimes available as low-cost "blem's" this could be quite affordable (about $45 each, instead of roughly $100 - $125 each), (For the purists among us, marine batteries are not true deep-cycle batteries, but in their construction a compromise between car batteries and heavy-duty deep cycle batteries, but they will work OK -- they just won't deliver as much power, nor last as long as their heavy-duty deep-cycle cousins.) A group 31 battery is roughly 115 to 120 A-h at the 20-hour rate, so a pair of these in parallel would be about 230 A-h at 12 volts, so fairly close... you'd be discharging these about 60% instead of 50%, which they should handle quite well.
Solar charging: This will depend on how much sun is available -- also, winter sun vs summer sun if you want this system to work year-round... If you can set up outside where your solar panel(s) get full sun nearly all day, and we're talking about summer time, we can count on roughly 6 hours of sun per average day here in VT, less in some places with even cloudier weather, and as much as 8 hours+ in places like AZ. Here in Vermont, I'd plan on an AVERAGE of 6 hours of sun per summer day. (This means 6 hrs per day average, allowing for rainy days, cloudy days, etc..., but you could get 14 hours of sunlight on a given day -- that just won't happen every day around here.
Typical battery charging (from any source) is only about 80% efficient (20% loss), and I need to replace 1600 watts of power used each day, so 1600 watts divided by 0.8 = 2000 watts. If I want to replace 2000 watts in one sunny day (at the average of 6 h/day in summer), means I would need 2000/6 = 333.33 watts of solar. A good match would be two 175 watt solar panels, BUT -- larger panels tend to be "24 volt" panels which would have to be stepped down to charge a 12-volt battery bank. (HERE is where we have the option to use a 24-volt inverter, and place those 2 batteries in series, which allows us to use the larger "24 volt" panels, which tend to cost much less per watt, than smaller panels. If you need to stick with "12-volt" solar panels, you could use 3 x 110 watts, or something similar. If you don't need to replace all that power in one sunny day, you could get a single solar panel, and allow it to charge for a longer time (or just charge from AC power, if available).
Charge controller: If your interest is summer only (or spring, summer and fall, but NOT winter), use a typical, PWM controller. For 2 or 3 solar panels of 100 - 140 watts, a 15- or 20-Amp controller would be fine (size depends on the short circuit current, or Isc, of the actual solar panels used).
Costs: Inverters can be as little as ~$75 for cheaper models I would not recommend, and for non-sine wave inverters you should expect about $300 or so; more if its an inverter/charger, with an AC charger and transfer switch built-in -- probably $500 - $600 for these. Pure sine inverters will cost more, and if made by a reputable company (buyer beware -- there are junky "truck stop" inverters out there!) will be between $ 500 - $600 for a good inverter, and around $800 - $975 for a high-quality inverter-charger. Basic charge controllers can be $65 - ~$150 depending on the features and digital readouts available. Morningstar Pro-Star 15 is a good option. 12-Volt solar panels are currently selling for about $ 2.50 per watt, while larger panels (nominally 24-volt) tend to sell for about $1.50 - $ 1.75 per watt. Batteries will cost about $125 each, or as low as $35 each if your local battery distributor can find some cosmetic seconds, or blemished batteries ("blems").
Total cost with solar panels, batteries, charge controller and inverter/charger would be around $ 900- $1050 for solar panels, and about $900 or so for the rest (using "Blem" batteries). This would be less if you used the simpler inverter (no built-in charger), and could be more if you bought full-priced batteries. Wiring this stuff up is easy, but you should add ~ $50 - $100 for wire, breakers and a small breaker box, so you can create a nice, neat pre-wired system with the components mounted to a wooden panel.
The premium system would probably be 3 solar panels of about 125 watts each, a ProStar-15 controller with digital display, and a Magnum pure sine 1000 watt, 12-volt inverter/charger with built-in transfer switch. That system can be plugged into grid power to charge batteries with the built-in 50 Amp (DC) charger, and comes with 2 pre-wired GFI receptacles. The whole works (solar, charge controller, inverter/charger and batteries would retail for about $2,125. The federal income tax credit (USA) would be 30% of the total, or $638, so the net cost after tax credit would be a little less than $1500. Using a good-quality inverter/charger and going without solar panels at all, would cost about $1000 less, or roughly $1150 but would not qualify for a federal income tax credit in the US (requires new solar panels).
Sorry that's so long -- hope it helps someone who wants to build a smallportable solar system!
safe spinning and clear skies,
Brad Vietje
Newbury, VT
