One Handle for multiple tools
phillip medghalchi
Hello, I have a problem with space in my shop/garage. I recently bought 3 new detail gouges form Doug Thompson, however, I bought them W/O handles so i can save. I asked him if he has one handle w/different adaptors that can accommodate these tools and he said no. I looked at Stewart Batty's Carbon fiber handle and adaptors and although they are very good idea it comes out pretty expensive and also looked at Dway handles. they are little bit less expensive, but nonetheless. Does anyone here know if there is anyway to get the adaptors that would fit different tools and fit one handle for anything that would be more reasonable. Not that those mentioned above are any bad, just little too much out of my budget for now. Any help would be greatly appreciated.
Re: One Handle for multiple tools
Dick Hines
Dick Hines
Phillip, what size tools did you get? There is a Kelton handle that is 1/2" at one end and 5/8' at the other.
Chuck Engstrom
Many chain hardware stores have bronze bushings among the items in those small slide-out cardboard drawers, in sizes that will often fit this need -- 3/8x1/2, 1/2x5/8, etc. Turning tools, it seems, are not spot-on for the size they claim to be, so I have had to split these lengthwise with a hack saw to get them to fit over gouges that are really 0.518 or 0.382, etc. The set screws of your multi-size tool handle will then be able to tighten everything up enough for use, and they're only a couple dollars or so each.
Best -- Chuck
phillip medghalchi
I got 1/2,3/8, and 1/4 form Thompson tools which he said the tangs are slightly smaller than the tool shaft itself. so, I got to see what I have to get.
phillip medghalchi
Mark, thanks for this I have to figure out what sizes I would need and then the other things is that what do you do with the old tools which have that spear like tangs like sorbey and or straight tangs?
phillip medghalchi
Chuck you are not talking Value. they haev wiped them out practicallyy out of San Antonio, TX. There used to be one about 1 1/2 miles up the road form me, but the big bouck stores forced him out of the bus.. Now, there is a church in the same build. I doubted they would have that. :D
A Contrarian View
Bill Howatt
I have a Kelton handle that came with my coring system, I have a homemade handle with a Hosaluk bushing I got at LV and another with a bushing I made myself out of some large brass rod.
I have to say that I just prefer to make a dedicated handle for each tool rather than do the remove/insert trick. Sort of like why I have more than 1 or 2 or ... chucks!
Bill
Chuck Engstrom
Sorry to hear that. The True Value here, my source for these, is reputed to be one of the chain's sales leaders for its size of area served, perhaps because the nearest big-box borgs are about 25 miles away. Even an independent in a another much smaller local store has them as well. If you want to try them, I can get them for you and send them along.
The borgs have those small-item collections too, but perhaps not all the items I have found in the local stores.
If Doug's tangs are right on size, so much the better. I have one of his skews, with a tang, and that I dealt with by epoxying the tang into a 1/2" brass tube, again from my local True Value. My homebrew handles use compression fittings which don't deform the brass as set screws would.
Best -- Chuck
Re: A Contrarian View
phillip medghalchi
I do respect that approach, however, my space restraint does not help me to expand. wife is already complaining that her brand new Hyundai is worth more than my hobby so, I have to be creative with the space. I like Stewart Batty's approach by having a twist on off handle to change, however, then I have to pay the price for it.
Dale Bonertz
Phillip,
Have you looked into Keltons ER collet handles. He now has ER16, ER25 and ER32. For the size of tools you own you would want to look at the ER25 and or the ER16. One twist and insert another sharp tool. To go from one collet to fit another tool is very simple. Unscrew cap insert new collet size and go to work. If you want good collets either purchase them from Kelton Inds. or Maritools work very well. Just make sure you put a caliper to your tools so you purchase the correct size range for your collection of tools since they vary a bit from one manufacturer to the next. Leave a little oversize on the top end so your biggest tool doesn't stick when trying to switch it to another.
I used to be one of the people who thought I needed a handle for each tool. Now I have multiple tools in 3/4", 5/8", 1/2", 3/8", 5/16". I got tired of storing all the tools with handles which took so much room. I have acquired, over time, five handles that each has a different collett size in it and I use it for all the tools in that size range (gouges and hollowing tools). As everyone knows it is easier to sharpen a tool without a handle and when they get to short to sharpen with a handle this becomes a non issue. I used to store one gouge per pvc pipe and now I can store three to six depending on diameter of tool. It surprised me how much more efficient this method is rather than a handled tool for everything. I love efficiency because for a professional "Time is money" and to a hobbyist "Time is precious".
I have no financial affiliation with Kelton tools. Just satisfied with some of their tools.
Dale
BTW, I had the opportunity to use the SB handles this past weekend. They are the lightest handle I ever used and are very precision made. My only problem comes with the ballister (I think that is what Stuart is calling them). You have to glue a tool into it. When you have 30 or more tools this becomes expensive. And if you want to use a hollowing tool with one of the SB handles and then a captured system this becomes a problem. He probably has a solution that I am not aware of. But overall they are very sweet handles and comfortable to use.
I prefer one handle per tool. It's just so much easier to simply pick up the tool you need. They can be stored quite compactly. Many people store them far too far apart and they take up too much room.
that being said I'm working on a traveling rig that lets me use just a few handles and have made adaptors for my tools so they fit these 3 or 4 handles. That way I can tailor my demos so I don't have to change handles constantly and will still have the tool in the handles.
I'm very interested in Johannes handles or Jimmy Clewes handles. These are very quick change handles if I had the same adaptors on every tool.
