Jet reverse chuck
Jet reverse chuck
Jet  reverse chuck
Darrin Hill
im trying to find a reverse chuck adaptor that jet makes... Friend has one and it's cheaper than the oneway one.... but i cant find it.. searched on the internet for a while, but i guess i'm calling it the wrong thing..
anyone know what im talking about?
a livecenter reverse chuck adaptor?
nova just came out with one but you have to add it to a livecenter.. im trying to find one that is one whole unit..
gracias..
Re: Jet reverse chuck
Bestwoodtools.com has one
Nick Todd
Caution: the manufacturers warn of using both version while the lathe is turning.
Darrin Hill
if im reading their website correctly, they only sell deadcenters... needing a live one..
Doc Green
Darrin, the only "live" adaptor that I've seen consists of a "live center adaptor" that screws onto the thread of a Oneway live center or a similar one that comes with Powermatic lathes.
The picture you included shows just that: a live center adaptor screwed onto the live center, with a chuck installed on the adaptor.
Packardwoodworks.com has the adaptor for about $42 and the live center for about $120.
The live center is a good investment even though it is a tad expensive.
~Doc
Darrin Hill
thanks doc... thats why i hang around u guys... :)
Terry Scott
Hi Darrin I use one all the time as seen on my Dvd
Larger sculptural pieces I often have two chucks fitted to a piece so I can swap back to front at anytime.The Vermec can be used with the lathe running as long as your head and tail line up as they have 2 bearings opposed to one on most reversing mandrels
Ive run mine full noise for hours on end
Enzo will supply any thread you want
http://www.timberlywoodturning.co.nz/products/Vermec-Threaded-Live-Center-.html
Penn State has one *LINK*
Craig Daymon
Depends on the spindle size you need (though you could use it with an adapter). They only offer one that is 1" x 8tpi with a #2 Morse taper and a 3/4" x 16tpi with a #1 Morse taper. Nothing for a #3 MT, so if you have a Oneway you're out of luck.
I had a good reason for wanting one of these, but at the moment I don't recall what it was. I'll have to write it down next time it comes to me as it was a good reason. Might have been to draw tension on spindles when turning thin spindles, though that can be done with tape on a regular live center.
Penn State - Live Tailstock Chuck Adapter - #2 MT
Cheaper on Amazon
Jclark58
http://www.amazon.com/PSI-Woodworking-Products-LTCA18-Tailstock/dp/B004CVJC1Q/ref=sr_1_49?s=hi&ie=UTF8&qid=1366039647&sr=1-49
Re: Jet  reverse chuck adapter
Jorge
Darrill,
That adapter is the best investment, and it has to be screwed to the live center. Buy th One Way and don't look back... It fits the live center of the Powermatic as well.
Craig Daymon
I may have misunderstood exactly what you are looking to find. The picture you show of the Oneway is the Oneway live center with the, sold separately, threaded attachment that allows you to thread a chuck onto the Oneway (or Powermatic/JET if in U.K.) live center. Both the Oneway and the live center that comes with a 3520 have a 3/4" x 10tpi thread on the live center. The adapter (several are available) has 3/4" x 10tpi female threads on the inside and a thread matching your headstock on the outside. The adapter sold by Oneway will work with the live center that comes with a 3520 (Powermatic or JET, depending on your locale).
You don't need to buy the Oneway live center if you already have the Powermatic/JET equivalent. Just buy the adapter. I don't believe JET/Powermatic sell such an adapter.
Otherwise, consider the Penn State adapter. It should also do what you want.
(You may find the price is about the same, or even less.)
Re: Jet  reverse chuck *LINK*
Darrin Hill
For some reason I thought jet made one that was one piece... turns out its an adaptor on a one way live center...
I have a nova live center... and teknatool just came out with this...
they should work together, and im a hobbyist turner... so ... unless the oneway will save my life or something by not exploding, or the nova one is bad, might be the way to go...
http://www.amazon.com/NOVA-5016-Tailstock-Adaptor-Accessory/dp/B0064JJ49Y
Re: Cheaper on Amazon
phillip medghalchi
It's weired that if you buy it directly from them you pay $34.+ and if you buy it on amazon, then you pay $27.00 and it ships form the same place, nontheless.
