Re: Sage
and a little Parsley and Thyme
That compressor, like myself, works in a non heated space, so most of the winter It does not work,
You should then drain it and leave it open during that period. Note, however, that there will be much less water vapor in the air to condense in the tank during the winter. My biggest problem in winter is that my compressor is located in the unheated garage. Takes more juice to get the cold pump started. I also put a "T" and manual valve in the drain line so that I can bypass the auto unit.
Also, you should consider an automatic condensate drain like the one that McMaster-Carr sells for about $60. When fitted to the tank drain, it will open for a few seconds to blow out condensate each cycle when the pressure drops by 10-15 psi. You need to check, clean, and lube it with synthetic grease at least once a year.
Keeping your tank's interior dry will extend the life of the pressure-trol, valves, regulator, and your air tools many times over.
