Question: Does anyone have a clue as to how to soften the "O-ring" material used in making the home made holders for vacuum turning. I will try to post a poor picture of the holder in question.
Bill, you can use a thin foam for the seal between the chuck and the workpiece and not have to worry about installing an O-ring. Almost any close-celled foam will work, or any foam that has a continuous film on both sides.
Cut a disk of the foam a bit larger than your chuck, cut a small hole at the center, and then place it between the chuck and workpiece as you apply the vacuum.
If you want to attach the foam to the chuck (on a temporary basis), simply use double-sided tape to hold the foam in place. When the vacuum is applied, the foam will be compressed and held in place, so all you need is a small strip or two of the tape to hold the foam during setup.
A foam thickness of 1/8" is plenty. Thicker foam will probably work, but too much thickness gives it a "spongy" feel.
A craft foam is available with the sticky already on it. Do a search for "Foamies" and see what comes up.
The stuff I use is from a left-over part of a roll of the foam that goes under those would-be hardwood floors that just snap together. An entire roll of it costs around $20, I think, and will supply you and all your turning friends for a long, long time.
I've also used packing material, and a lot of etc. If the foam has a continuous film on both sides, it will work.
I use "foam sheet" which can be purchased at Walmart, Hobby Lobby or most good art supply stores. They come in 1.5-5 mm thicknesses, with/without adhesive backing, and in various sizes. A typical sheet 9"x12", 2mm, adhesive backed costs about $.99
I recommend the adhesive backed 2mm thickness sheet. The thicker sheets will compress too much, making it difficult to keep the workpiece in alignment
If you're trying to soften it to put it on the chuck have you tried setting it in hot water (not boiling) for ten minutes or so. If you're trying to soften it prior to use then I am not sure since all methods would be a short term fix.
There used to be a product called "green Soap" that we used to apply to the rubber bands for model airplanes. Probably could get it at a drug store or maybe hobby place.
Bill What are you trying to do. Has the O ring gotten hard and brittle or are you using just a regular O ring. Regular O rings are too hard and simply don't give. I tried them and they work but the work can't have any irregularities.
Have you seen the latest issue of American Woodturner. I think he went a little overboard you could just cast an O ring using his method. Of course his method lets you seat stuff where the material has to go inside or outside not just on top.
I also use the thin closed cell foam that you get at Hobby Lobby. It's dirt cheap and works quite well.
I'm a "rubber guy". Once the rubber is cross-linked, not much change possible. This is why it is so difficult to recycle. You may find softer silicone ones (even sheets) available in like McMaster Carr or equiv. I'v tried different duro's of rubber parts, etc. Be careful most rubber, unless "non-marking" will leave traces on your project. I use the foam from Walmart.
I use 3/32" neoprene for the ring that gets glued to the check, folded over the outside of the drum and then taped into place. The "final" seal is a loose piece of either a plastic grocery bag or plastic wrap with a hole in the center. The plastic wrap gets changed out with each piece and prevents marks as well as abrasions from any dirt (wood, sanding grit) that gets imbedded in the rubber during use.
I bought adhesive backet neoprene from Allstate Gasket online. Or you can look for a local supplier of thin neoprene in your area, use solvent based contact cement and make MDF chucks
