Mini router
Mini router
Mini router
I've been using my mini router on the lathe for years but it always had some problems. So I spent yesterday and today reworking the router support so I could cut with different bits and different angles.
then it dawned on me that I had all the parts around the shop to control it with micro precision so I started putting that together.
Eventually I hope to add an ornamental style cutter because it will make cleaner cuts and I can grind my own shapes.
Re: Mini router
Very clever John
Jorge
Good solutions, thanks for sharing and timely for me, because i am trying to star doing something like that.
What is that right on top of the lathe bed? a cross slider?
Re: Mini router
I made a horizontal sled for mine
Mike Foster
which uses the fixture at the end that allows me to change the angle of the router in the sled. I use the flat table in the banjo as a platform. I don't have that nice micro adjuster horizontal fixture that you have. What is that and where did you get it? Inquiring minds want to know.
Re: Mini router
Here's what I normally use
Mike The two fixtures I am combining are a cross feed table that I bought from Enco many many years ago to use on my drill press. The bottom one is a rotary table for work on my metal lathe. Not the best combination bu I had them so the cost was minimal.
I normally use a wooden table that fits in my tool post. I have one that is adjusted with threaded rod, and another that is just a straight rod and I adjust the height with PVC rings.
Re: Mini router
Leo Cuellar
Re: Mini router
Leo Cuellar
Slick setup, John! I have all that stuff, but never thought of combining it that way. I'm glad you have time to figure this stuff out for the rest of us. :)
