REAL MILK PAINT
Air compressor question
My pressure drops from full pressure to about 24 psi (I'm guessing) about 5 seconds after you squeeze the trigger to blow off stuff. I'm guessing it might be the pressure regulator. I did have to replace the pressure switch about a year ago. So my question is, do you think I'm correct or is it the switch again. The little regulator knob thingy, is fairly inexpensive, the switch isn't which is why I'm trying to narrow it down.
Re: Air compressor question
Chuck Engstrom
Hi John -- It sounds like you're saying that the pressure drops off at the nozzle of your dust-off thingy. Does it drop off all the way back to the tank? In that case the pressure-switch should bring the compressor back on, shouldn't it? Does the pressure come back up quickly to the dust-off? Or does the pressure regulator just seem to get stuck?
What happens if you take the regulator out of the line and just go compressor to dust-off? If the pressure stays up then it seems to me it must be the downstream regulator that's causing the problem.
Best -- Chuck
Darryl
John, don't you have two gauges? One showing the pressure in the tank the other the pressure at the outlet (the blow off thingy)? If so which one drops off the one on the tank or the thingy pressure?
Pete in Holland, MI
Assuming you are indicating the line pressure drops, and not the tank, it sounds like either the regulator is stuck, or something in the line is impeeding the flow.
Is the tank pressure holding well?
Is the compressor cycling on once you reach 25#, or does it take several blasts of the hose to trigger the compressor ?
Can you remove the regulator from the system for a trail without it?
If it's the regulator, try cranking it all the way in, then out, then in, then out. If you still figure it's the regulator, check with one of your factory friends and get one built for commercial duty from their junk box.
Let us know what you find.
Pete
turns out it was a stuck ball valve. As I was playing with everything trying to isolate the problem it came unstuck and started working fine. I'll pick up another one in a week or so and replace it just to be sure.
I do have a bigger compressor to replace this one but have to run about $400 worth of new electrical wire to make this and my new (to me) dust collector. work. They both run on 220 and the line I originally ran to the shop is just to small to handle the lathe and those two running at the same time.
have you ever flushed your compressor?
I was loosening the drain valve and it was only sort of leaking goo so I decided to remove it. Not smart. Had a sort of air/goo explosion and covered about half of me and blew the valve out. Surprisingly I found the valve, cleaned it, and me and put it back in after the compressor stopped draining. Turned it back on to fill up and let it drain again. It was blowing clean air now.
What I want to know is has anyone ever flushed out their tank. Since I have to partially dissassemble it from the top to replace that valve it won't take 5 minutes to pull everything off so I could run water and maybe some detergent in and flush it clean. Then run it through a couple of air/dump cycles after putting it back together to get it sort of dried out.
Whatya think, dumb idea or worth the effort.
There is probably little reason......
JamieDonaldson
...to flush the tank several times, as it will continue to collect moisture with use. Emptying the tank several times a year with normal use will give the same results, a small river of rusty water that can permanently stain a concrete driveway, and don't ask how I discovered that!
Re: have you ever flushed your compressor?
Josh Bowman
John,
Our compressors at work have and auto drain, but the operators still bypass it to ensure the tanks are clear. I hard piped a copper tube outside my shop and have a ball valve I just dig down to and blow it down once in a while. it's amazing how much water is in air.
Bill Gasper
John,
I have never flushed my compressor tank. Instead I just drain it. My portable compressor is a pain in the *ss to get to the turn-cock and unscrew it so it doesn't get drained as much as it should. My stationary compressor has an auto drain that is plumbed to the outside - works great. There is a bypass valve on the auto drain but I've yet to find any residual water in the tank. You should consider installing one when you get your larger compressor hooked up. Some day I'll reconfigure the drain value on the portable to make it easier to use...
