Two recent tool handles
Craig Daymon
I made these over the weekend. One is Padouk and the other Curly...Maple(?). (Pretty sure it's Maple.) Hosaluk inserts. Finished with Mahoney's Walnut Oil. I may apply some paste wax over that.
I'm fairly confident they'll hold up to all but the most aggressive usage, but I think the best grain orientation would have been with the set screws aligned such that the insert is rotated midway between flatsawn and quartersawn grain. In these it is oriented with the flatsawn orientation.
One thing I might consider on future handles with these inserts is to cut a recess in the upper node where the current grooves are and use the string based ferrule in that section. This will better brace the insert and should look pretty good as well.
-Craig
Re: Two recent tool handles
Mike Stafford
Great looking handles, Craig!
I think they are great handles. Very well done and should last a long time. However for discussion sake there could be a weak point at the V cut just after your first detail. It probably isn't for this handle since your metal insert probably goes beyond that point. I'm just suggesting that if you were making a handle with the steel just inserted this V cut takes away a lot of wood and could make it weak.
Now in reality most tools aren't going to have that much pressure there and it would never break. But if it's a bowl gouge and the metal isn't inserted very far I would want to keep this area as strong as possible. I think that's whey a lot of tool handles have the bulge that enlarges from the ferrule and just keeps getting bigger both to keep the handle from breaking and to be more comfortable for the hands if you use a short grip.
Craig Daymon
Hi John. Thanks for the compliment. I'll try to put them to use this weekend, though I do have a bit of a "new workbench" feel about them. Still got to break them in sometime.
The impression is that the V cut would weaken it and it does in the sense that the handle is smaller in diameter at that point, but the part in front of that V cut is probably much thicker than it would be on other handles. The V is cut to that depth, not compressed, so the weakness only comes from being smaller in diameter at that point.
The Hosaluk insert does extend beyond that point and I did use epoxy to put it in, so it's less likely to fracture, like CA might. The epoxy should even add strength to the wood that it has seeped into.
As I stated, I think there is weakness in the grain orientation if I want to keep aligning the flutes with the lock nuts, but I don't have to do that. (That does irritate me that I didn't think that through correctly, but I liked the way the flatsawn grain pattern sort of pointed to the set screws.)
I do see the argument that they lack ferrules. I'd consider fixing it on the shorter one by returning the upper node and using string. I can't with the longer one because with the insert in, it exceeds the capacity of my mini lathe. It's right at 14" without the insert.
Don Leydens
Sweet, Craig!
Thanks.
Craig Daymon
I'll try to remember to post pics (so we can call in C.S.I.) if one breaks.
John mentioned the shape. I based this shape off of what my Crown Pro-PM tools have and it also resembles what Hunter puts on their tools.
Thanks again for all good words (and useful critiques).
-Craig
