Turning a mallet from ipe
Alex Y
I have a few cutoffs of 1x ipe lumber, and think it might be nice material for a mallet. While I'm not a complete newbie at turning, I certainly am compared to this group, so I hope I can benefit from any relevant experience you have. My questions:
When gluing up the blank, what glue and special preparations would you recommend?
I'm thinking of using a different, lighter, wood for the handle. If so, should I glue it up with the head? My inclination is not to, since the woods would have different movement, which might eventually break the glue bond. I was thinking of leaving a 1x1 empty core in the head, and attach the handle with wedges.
Anything I need to be aware of in turning ipe, other than planning to do lots of sharpening as it dulls my tools?
Re: Turning a mallet from ipe
Ipe decking would make a beautiful.......
JamieDonaldson
....and functional mallet head, but I was questioning myself about what glue would be best for glue-up that could withstand serious pounding? The handle should be a sturdy wood like hickory or ash, with a fitted handle and wedge to secure without depending on a glue joint.
Wear a dust mask *LINK*
Craig Daymon
That yellow powder that is lodged in the pores of Ipe is one of the reasons it is resistant to many bugs and not very good for people. The Wood Database reports skin, eye and respiratory irritation from it.
-Craig
Wood Database - Ipe
You're right about ipe's dulling effect on tools. I once burned out two carbide router bits in about five minutes of routing endgrain ipe. Keep your grinder handy.
One other thing: You might want to experiment with glues and glue prep before you commit to one way of laminating the stuff. About five years ago, I made an outdoor bench out of ipe and glued it together with West System epoxy. Most of the joints have stayed together, but the edge joints in the top bench surface have opened up -- failed along the glue line itself, i.e., the wood is stronger than the glue. I suspect the real reason it failed is because of shrinkage due to the ends drying out, more than the center section. This may all be academic to your current project, as I don't imagine you'll be leaving this mallet in a damp location, but it may be interesting to find out which glues stick better than others.
Please post a follow up after you complete this project. It sounds like a good one.
Absolutely
Richard T. Jones
This is THE worst, as far as I'm concerned, that I've ever worked with, period. A really hard wood: hard to work, hard to finish, and hard on YOU.
I turn coasters from the deck boards and give them to friends for "shop coasters", as they help to eliminate rings on your bandsaw table.......
Dick Coers
Results across the internet are really mixed on what glue to use. Since you have scrap, just give it a try. Some say Titebond III, others say urethane. I would suggest adding some cross dowels to add some mechanical strength to the joint. Ipe does make some fantastic small box finiales. I've turned it down to 1/16" diameter. Also makes fantastic crochet hooks. I polishes so nicely with no finish required, and can be worked into the hook with great results.
bill Crommett
Some years ago I bought a board of Ipe at am lumber yard in Charleston SC. The yard boy refused to cut it in two pieces to fit into my auto, so I had to go back to my BILs to get his saw to cut the board.
