Doc Green's thread on the breakage of handles made me think of something else; the woods from which handles are turned.
It seems most tool manufacturers use either maple or ash for handles. I have often wondered why hickory which is the handle material of choice for lots of garden tools and in the past carpentry tools is not used for turning handles as well.
I have made a lot of my homemade handles from oak because I have access to lots of it in 2-2 1/2" thick stock. One of my favorite handles is turned from cherry.
For the last several years I have been using machined aluminum ferrules which are inserted and glued into a drilled hole in the handle. Using these ferrules I have made short spindle work handles, 7-9 inches long, from a variety of exotics which enables me to distinguish between my tools just by looking at the handles. I also like the heft that the dense woods provide in my hands. Using these ferrules allow me to vary the projection of the tool out of the handle. I can also reverse my tools and insert the cutting edge inside the handle when I travel. Since most of the wood I do is spindle oriented work on relatively small items I don't need the leverage afforded by longer handles. Short handles also allow me to work in front of my body instead of from the side.
Someone mentioned that in a thread on SMC handles constructed in this manner had been a problem for them and the aluminum ferrules had split the wood. I have been using this method for most of my tools for several years without any problems.
Here is a picture of the type of ferrule I use. Frank Penta has these made by a machinist friend of his and sells them through his turning club.
I usually use ash for my handles although I made several from walnut a while back. I also have some made form some kind of exotic that I got from my brother. He works at a marine dock and it was on one of the boats that unloaded there. It was a hard, dense wood and was a light ornangish-pink. It made nice handles. That said, I like the ash better
I use brass ferrules that one of the club members keeps on hand in the library cabinet in Erie, PA. I've also bought ferrules but they are not as good as the thicker brass I can get at the meetings. I've used copper pipe fittings but they don't look "authentic" I've got several of the eccentric ferules that Doug Thompson makes but haven't used them.
I really like the ferrules you use Mike and would think they would hold up well as long as there was enough meat left around the tenon and the fit wasn't too tight.
Mike I haven't used any of those but it seems to me like it would weaken the wood since you have to drill larger hole, hence less wood. However they do look like they go fairly deep.
I use all sorts of woods, sometimes glueing up contrasting blanks. Most of my currrent homemade tools have ferrules made from brass compression nuts. The are hex nuts with threads on the inside. I cut the tenon just a hair bigger than the inside diameter of the threads and then thread them on. I take them back off and put some CA on the wood and then screw them back on. Then I turn the hex down to round although you really don't have to do this if you don't want.
For traveling I'm getting ready to make a bunch of handles out of PVC using aluminum inserts with set screws. I will have to make the inserts which look like the metal ones you posted. This will keep my tool weight down and allow me to store then entire tool inside the handle along with my contraband etc.
John, everybody says that but if you consider in most handles the biggest bulge in the wood of the handle is right near the end where the ferrule is you can see that there is plenty of wood for support. I have put lots of pressure on these ferruled handles using a 1/2" Thompson detail gouge for deep end grain hollowing and never had a problem.
Knock on wood! I don't want any problems either. Like I said in my initial post I don't use them for anything but spindle tools which I don't project all that far over the tool rest.
To avoid confusion in this discussion, I suggest that a 'ferrule' is the band (typically metal) used around the end of a wooden handle to prevent outward expansion of the wood under the forces created by using the tool.
The machined aluminum parts Mike has shown are described by Craft Supplies as "handle inserts" [ See: http://www.woodturnerscatalog.com/p/7/2/34/140/-/1902/Hosaluk-Handle-Insert/hosaluk+handle+insert ] and are not ferrules, since they do not encircle the wood to provide support. It is not surprising that some have found splitting problems if these types of inserts are used without a ferrule, particularly if larger tools, such as bowl gouges, are used where forces between the tool and handle can become significant. For smaller/shorter tools or shorter handles where forces do not become large, use of the inserts without a ferrule may work just fine. For safety, use of the insert with a ferrule would reduce or eliminate the chances of splitting at the end of the wooden tool handle.
Oneway has solved the problem by including both tool-adapting insert AND ferrule into one machined unit, which requires turning a taper to fit inside of the base of the unit, thereby preventing expansion. See: http://www.oneway.ca/index.php?option=com_virtuemart&page=shop.browse&category_id=64&Itemid=2 I have not used one of their ferrules, but have heard from others that it is a bit tricky to fit the handle to the adapter, since it needs to be a "screw-on" fit.
The "Quick Release" Handle Adapters (made by Doug Thompson) that are sold by Jimmy Clewes [ http://www.jimmyclewes.com/clewes/GeneralWebsite/Shop.aspx?Feature=14 ] include BOTH the adapter (an eccentric, twist-lock style) AND a machined ferrule. I have a couple of these, and it is quite easy to fit the ferrule onto the handle end before drilling and adding the insert and gluing it in. Here are images of a 3/8" adapter and ferrule fitted to a handle turned from bocote:
I agree with the comments about using a variety of different woods for tool handles. The benefits of easy visual recognition of the tool make for a more efficient turning operation.
I don't know why I called them ferrules in this thread. I have never referred to them as ferrules before and have always called them adapters. I am fully aware of what a ferrule is.
A noxious gas brain emission I am guessing is responsible.....at least that is the excuse I am making.
I like using them for a variety of reasons and as previously stated have not had any problems.
They are like the Hosaluk adapters but are much less expensive and the diameter of section which is inserted into the wood is smaller in diameter than his of comparable capacity.
I just made 2 handles using Hosaluk inserts this past weekend. (I'll post pics soon.) Hope they hold up. They sure look pretty. One is Padauk, the other is curly something. Might be Maple, but I'm not certain.
I thought I chose the correct grain orientation when I epoxied in the insert, but I think I did just the opposite. (Wanted the set screws to indicate flute up.) I aligned the set screws with the flat sawn side rather than the quartersawn side. Though maybe a point halfway between is best?
Could you describe these PVC handles a little more? PVC will shatter, so it doesn't sound like the best choice to me.
I could see making handles, like several people already do, using aluminum tubes covered in plastic hose. The hose giving you a comfortable grip and the aluminum tube giving strength and he option to fill with shot for more mass. (Like Oneway and several others.)
Craig, you used to be able to buy aluminum adapters that fit inside schedule 40 pvc pipe from Hunter Tools. These adapters allowed you to make a lightweight handle that held the tool shaft in place with set screws.
Here are a couple of pics... Sorry they are so small.
I forgot to mention I made a handle using these adapter in wood and it has held up very well. The adapters are glued into red oak and the handle has been abused both as a holder for a spindle roughing gouge (pictured) and also for bowl gouges.
I would not use this type of insert without a ferrule around the shaft part. A lever inserted into the grain with an orientation similar to an axe wedge will fail eventually. Kind of like turning end grain with a chuck in expansion mode.
PVC makes a great handle with the aluminum insert. The insert takes the force so I don't think you would break the handle very easily. Besides I never get catches anymore. I got this insert from Mike Hunter. I looked on his website and he didn't have them listed anymore unless I just missed them. I plan to turn my own. It will be good experience for using my metal lathe.
Here is a quick selection of some of the ferreles. All the Brass ones are copper pipe fittings of some sort or other. I like the solder to thread adaptors because you can get them in sizes that roughly match your metal on one side and threaded on the other. These turn just like the compression fittings but they have more metal to work with. ON compression fittings if you take down to much brass you cut into the threads. Bummer, still holds, I have 2 tools where I did that and have been using them for years there just ugly.
The string wrapped one is a skew I made about 5 to 7 years ago.
And don't forget the Clay Foster custom ferrule. These are great for removing the tool from the handle for sharpening. Can't even remember how many years ago it was the Clay showed this but what a fabulous idea.
Well Reed, I and lots of other people I know have been using them for years and I know of but one failure and that was someone on SMC and I don't know the details.
I have had no problems with them the way I use them. You will note that my recommendation is for tools that are going to be used in spindle turning. I do use them for hollowing end grain everytime I turn a box.
Next time you make a Three Point Tool, use a brass hex nut for the ferrule but leave the flats on it. Then you can place alternate flats on the tool rest on the grinder to sharpen it.
Barry Good idea. I have a flat filed in the round shaft and a Nut with a set screw in it that I can slide on and lock in place. Your idea is easier other than the tool rest may have to be far away if your shaft is long.
