New hollow vessel
New hollow vessel
New hollow vessel
Well it's been a while since I turned one of these. I wanted to try out this collar or ring idea that I sketched out one day. I have well over twice as long making the collar as I did turning the vessel. Not a money maker for sure. At least not in my area. About 3 1/2 hours work mostly on the ring.
The vessel is Box Elder and the ring is Blackwood. It's about 6" across and 5" tall.
Re: New hollow vessel
Don Leydens
Don Leydens
Terrific wood and form John. Personally, I wouldn't mind if the ring was a bit shorter. Love the contrast of the two woods, just think a smaller collar might calm it down a bit.
Did you sand that indentation (upper left) or was it that smooth to begin with? Looks great.
Randy gleckler
Very nice John, the Ring looks very very cool
Don that's not an indentation that's some figure in the wood. I agree with you on the thickness of the ring. It's one of those things that looked about right when I was fitting it on the vessel but when I took the photo I could see that it was too thick for this form. The whole idea behind this concept was to have the flutes go into the neck and that part worked. Now I just have to figure out how to do it much much faster. Either that or ask $10,000 for the vessel, then it will be worth my time. :)
Don Leydens
Don Leydens
Don't worry John, if there is a way to make those collars easier or faster, you'll find it! :-)
Harry Robinette
Harry Robinette
I like the piece allot but I believe the collar is a little high. I've been taking a picture while on the lathe and look at it a couple times over the night. it really has helped with my shapes at lest I think so.
