Orientation of Compression Wood - Hardwood vs Soft
charlie belden
Is this true?
Re: Orientation of Compression Wood - Hardwood vs Soft
Wow, I'm not sure. Most of the limb woods I've turned have had the annular rings closer on the bottom but I've never really thought about it being different for soft woods. Since most of the time what I have when I get home with it is just sections it never occured to me to see how it was in the tree. We have a lot of freshly cut up trees around here right now. I will try to look.
robo hippy
Well, first, 'hard' wood and 'soft' wood are not accurate terms. Second, I saw this years ago, and checked with nearly every tree I had access to since then. Every single time, on a side branch, or on a leaning tree, the pith was always on the up side. This does include a pacific yew or two.
robo hippy
bill Crommett
A more illustrative diagram would continue the annular rings back into the trunk to see where they deviate from the straight and narrow or the circular to oval.
Same as Robo
Jorge
The "muscle" is always at the bottom and the pith near the top.
Boy, is that counter-intuitive!
