ADVERTISE HERE - FREE TRIAL
Shipping wood to Australia
Mike Foster
Anyone sent wood to our fellow turners in Australia? I've sent wood to NZ before and found that it presented some major problems in customs. I am sending a completed piece of work for a trade, but wanted to send along some of our local wood as well. I looked at some info on the web regarding wood and it sounded like the real red flags were bug holes and bark. I would be sending neither. I think the same really applies to wood sent to NZ, but that didn't stop it being a big hassle for Terry Scott, who I was sending it to. I think he even had to pay for their fumigation of the wood. If there is a possibility of this, I would just send my completed piece. Any help is really appreciated.
Re: Shipping wood to Australia
Wood exports to Australia *LINK*
Here's a summary of Australia's wood import policies. I've found that most countries require that wood shipped from the US be heat treated. Here's an excerpt of the ISPM 15 regulation that currently governs export of wood products and packaging materials to over 175 countries, including Australia.
Currently, two types of treatments for WPM items are prescribed in ISPM 15:
Heat treatment (HT), and
Fumigation with methyl bromide
Either of these treatments must be applied to all solid wood components of the wood packaging materials, both hardwood and softwood species of wood. Solid components generally mean the lumber, timbers, or smaller items produced from lumber or timbers. Heat Treatment requires that each solid wood component must be heated to a minimum of 56 degrees C (133 degrees F) for 30 minutes at the core of each piece. Composite wood products such as plywood, particleboard, oriented strand board (OSB), flakeboard, and veneer are exempt from this standard due to the fact that high temperatures are used in their manufacturing process. Preservatively-treated (pressure-treated) wood does not meet the Standard unless the wood was heat-treated and stamped HT prior to preservative treatment.
Australia's import regulations
Re: Wood exports to Australia
Mike Foster
Thanks Ellis. Sounds like a little hassle, but I'll investigate a bit further to make sure it goes through OK.
