Jaw stain
Jaw stain
Jaw stain
mjonesrdg
My NOVA chucks (with the various jaw sets) stain the tenon on wet woods. This problem seems to be a growing problem and I am wondering if the "finish" on the Jaws is wearing thin, thus exposing the steel? Have any of you had this problem? Figured out a simple fix? Do any of the chuck makers sell stainless steel jaw sets? Suggestions?
Re: Jaw stain
Re: Jaw stain
John Veerkamp
Coat the area where the jaws will contact the wood with shellac or lacquer. And don't compress the jaws too tightly.
Re: Jaw stain
Re: Jaw stain
robo hippy
I don't think the jaws on any chucks are stainless steel, so you will always get 'rust' type color when you turn green wood. If you are going to return it later, no problem as you will be able to cut it out. If you turn to final thickness when it is wet, just put some concentrated lemon juice on it. The black colors are gone in seconds. If it dries with the black metal stains in it, it will take a couple of minutes, and maybe a couple of doses. If it is a metal stain from something stuck in the tree for years, you might lighten it up a bit, but it will never totally go away.
robo hippy
Re: Jaw stain
Re: Jaw stain
Galen Vetterick
There is Kwik-Blak LT which is a liquid black oxide coating system you can do at room temperature. Probably match a lot of jaw coatings now. Might try Birchwood Casey's gun blue or browning systems if your into shooting.
So why not coat them with a good coat of paste wax before you use on green wet wood. Will not really effect holding power or at least from my experience but lets me clean them up easy even if they get spray finish on them.
Re: Jaw stain
Lyle Jamieson
Re: Jaw stain
Lyle Jamieson
If I jury a show and I see any remnants of the chucking method it gets dropped down a notch. What is the difference in having screw holes left in the piece?? I don't like to see chuck jaw teeth marks or even a recess where a chuck might have been. I look for a sweet flowing line of the vessel where the side wall meets the bottom without a flat spot where a chuck might have been shouldering. My 2 cents...the discoloration will not matter of it is reverse turned to finish the bottom.
Re: Jaw stain
Mike Stafford
Re: Jaw stain
Mike Stafford
If there is the slightest hint of tannic acid in the wood you can almost count on some black staining. Most woods have a hint and some have a lot more than a hint.
Allow for removal of this by making sure that the base of the tenon being held by the chuck is not in contact with what will become the bottom. As Lyle says if you reverse turn the piece you should be able to turn it off.
Re: Jaw stain
Re: Jaw stain
robo hippy
Paste wax will make no difference, at least not when I tried it. I did stretch nitrile gloves over the jaws, and because they are so thin, you can still get a fairly good grip. I had a friend who used the gloves as well, and would cut out a circle and secure it with a rubber band. Worked okay as well. I stopped using that method. In part, too much trouble/one extra step in the process, and when coring, the blanks would tend to slip.
As for a recess remaining on a finished piece, with utility bowls, I never bother to remove it. Clean cuts, sanded and finished it looks good. You have a spot that won't rub on the table, so your signature will stay just about forever. It is an extra step, and you don't get any more money for doing it that way. The people who seem to care most about evidence of how you held it while you turned it are other turners, and not the general public. For a dust collector (artistic piece), I will generally turn them off. If you use a tenon, you pretty much have to finish it off, and make sure to blend it in near the bottom. Some of my warped pieces move so much that flattening out the bottom would be impossible anyway.
robo hippy
Re: Jaw stain
Dick Hines
Re: Jaw stain
Dick Hines
Use a larger size jaw set on your chuck. Then you can just turn the stain off.
I stopped using the tenon for a foot. I make sure there is enough wood in the bottom of the bowl to turn a concave foot for the bowl to sit on. It makes the bowl look like it is sitting INTO the service.
Re: Jaw stain
Re: Jaw stain
mjonesrdg
Well, THANK YOU Robo Hippy! Of course I know how to turn away some uglies, but there are times when that presents problems...natural edge hollow forms, bottle shapes turned from the bottom, ultra thin walls...etc.
I owe ya a beer!
Re: Jaw stain
Re: Jaw stain
robo hippy
Thanks for the offer, but it would have to be a root beer. Can't remember who told me the trick about the lemon juice. It will also cut a lot of the walnut stain from your hands.
robo hippy
Re: Jaw stain
Re: Jaw stain
JoHannes Michelsen
Best way is buy some flat plates replace your jaws with the attach wood and turn wood jas that will not mark mar or color your work.
Best kept secret in the Woodturning world!
