wooden tool rest
wooden tool rest
Jack Guzman from Maine
wooden tool rest
I hated moving the too short mickey mouse tool rest that came with my grizzly lathe back and forth to turn spindles. When I saw Curtis Buchanan's utube videos of his chairmaking I noticed that he had a wood attachment on his lathe bed.I decided to build something of wood to replace my tool rest. The base has a slot so it can slide in and out and holes in the back for turning tools. I threaded furniture screws into the face with a standard machine thread exposed. Using wing nuts to attach it I made three different sized rests out of poplar. After using them for awhile I noticed that the wood dented too easily so I attached steel to the edge. I have been using these for over a year now and they work slick.
Has anyone else ever done anything like this? I can make any size rest I want with a piece of board and a piece of steel available at any hardware store.---Jack
Re: wooden tool rest
Bill Turpin in WNC mountains
My first lathe came with only a 12" rest. It was impossible to turn prns. I took a 4" piece of 1/8" angle welded to a 1" post. I added a maple strip, cut at an angle, wooked good. I still use it ten years later.
Jorge
Jack,
without reading the other posts, my initiation to turning was making stairway spindles, heaps of them, the lathe had a long bed and two banjos with a white oak board attached to the posts, it was stiff and smooth and had the shape of the spindle, so there was no measuring or comparing, it was sort of a duplicator. when we had to make a different spindle the board came out and another with the new pattern came in.
I thought it was veru slick and did work very well.
Doc Green
Here's my entry into the wooden tool rest contest:
I needed a small tool rest with a thin vertical profile so I could get my shop-made hollowing tools (Allen wrench variety) close to the piece being hollowed without having the ferrule of the handle hit the rest.
The body is wood, of course. A 1" aluminum tube with a tight-fitting plug goes into the tool rest holder. A 5/32" music wire forms the surface for the tool to rest on.
Works like a charm. ~Doc
Mike Stafford
Mike Stafford
Doc, love your solution as it was much cheaper than mine.
I like to use my live center in support when I have a lid jam chucked upon the body of the box while I am shaping it. It is hard to get a tool rest in that confined area sometimes.
Your tool rest would work but the Robust tool rest works great because it can be reversed and used from the "wrong" side and fits in tiny gaps. Love my Robust tool rest but your idea is a winner.
Do you just use a scraper with that rest?
Dick Coers
How do you get the handle down low enough to work with gouges with all that wood in front of the steel? Not very flexible for moving it around either, but seems to solve a problem for you.
Steven Antonucci
I'll be making some of these, too.
Re: Do you just use a scraper with that rest?
The steel sticks up above the wood so the tools never contact the wood.I don't use scrapers so I'm not sure what you're talking about. However,the only thing I had any problem with this rest is in fitting a steady rest. As for moving around,the only thing holding the base to the lathe is one bolt through the slotted center. The nut(below)has a handle welded to it so no tools are needed to loosen the base.The base is slotted to move forward and back and sliding right and left is easy.
I turn chair legs. I put my blank between centers and set the rest to just clear,then rough it out. Then I slide the rest as close as possible and using roughing gouge, skew and parting tool I make a leg. To sand I just remove the rest.(I'm not good enough for a skew finish)---Jack
I just looked at my pictures and I think I know what you mean. The board looks to be flat on the top edge but it's not. The top edge has a steep slope for tool clearance.It's just a bad picture(blame my cheap camera)---Jack
