My tree man is getting married, poor guy. He wants me to turn him a couple of rings. does or has anyone turned rings? If so how do you hold them to finish the out side. And what kind of finish would be good.
And to make things better he is bringing me a 12" holly log and two spalted gum logs. Life is good.
Dick, I turned a bunch of them when I was in high school, almost fifty years ago. (I didn't say fifty, did I?, maybe 45 give or take.)
This was before I had a chuck, and I only vaguely recall doing it. I would say mount the piece so you can turn the inside and sand it nicely. then mount a mandrel on the lathe, in a chuck. You can wrap the mandrel with sand paper or double stick tape if necessary. This would be a gently tapered dowel. Use it as a jamb chuck to finish the outside.
I drilled holes in mine and then used a dowel with sand paper wrapped around it to sand the inside. Obviously you need to know what size to make the hole. Some of mine ended up being way off center, but those were popular because they looked like they had a setting. Most of mine were walnut. They would be sturdier if you glued up some laminations.
I have used a variant of Barry's approach. I turn a narrow notch (narrower than the ring width) in the tapered mandrel at the point that matches the inside diameter of the ring. Then, I split the mandrel on a bandsaw from the free end of the mandrel to a point well beyond the notch. Then I split it again rotated 90 degrees so that the end view of the mandrel looks like an "x". To use it, slide the ring onto the mandrel up to the notch and then screw a suitable sized wood or metal screw into the free end of the mandrel to expand the slotted mandrel until it is snug against the ring. The notch keeps the ring aligned so that it does not wobble during sanding and finishing.
shows how to make a ring -without- using a chuck. To shape the outside, he slips the ring over a tapered mandrel held between the Morse taper of the headstock and the live center.
By using a chuck, you can simplify his procedure considerably, but he has some good ideas. "All you gotta do is watch."
I have turned exactly two rings. The biggest problem for me was getting them sized correctly. I had the persons for which they were intended go to a jewelry store and have their finger sized. Once I knew the size I drew circles of that exact size, cut out the hole and turned cylinders which would fit into the holes snugly.
Then I mounted the stock on the lathe and turned a cylinder. I mounted a drill bit close in diameter to the hole that I needed and drilled hole deeper than needed. I carefully shaped the inside of the ring surface so that both outside edges were slightly larger in diameter than in the center of the ring to make it easier to put on the ring.
Next I shaped as much of the exterior of the ring as I could without parting it off. Once I had most of the exterior profile shaped I parted the ring off and jammed it on a soft pine cylinder and finished turning the outside of the ring.
I was using cocobolo at the purchaser's request so fine sanding and wax was all that was necessary.
They still wear the rings but both have turned almost black over the last 3 years.
By the way, carefully check your stock for cracks and checks as they could lead to a split when you jam chuck the ring. Only happened twice for me before I used another stick of wood.
Seems to me there was a major article on making rings in either American Woodturner or Woodturning Design within the last couple years. A search of those sites should reveal the article. ...GG
