Has anyone been brave enough to purchase carbide tipped band saw blades? They appear to be 5 times as expensive as regular blades. I go through quite a few blades cutting blanks for turning. If the carbide blade would last longer or cut better it might be worth it. I am looking at the 3/4" x 137" ($200+ on eBay). I will wait until I hear from the gang here before diving in and buying one. Maybe they break before they wear out.
As my local bandsaw blade guru told me when I was first checking out bandsaw blades, "Carbide tipped blades are for cutting veneers". I did try one out, and he was right. As far as I am concerned, the best blades are the Lennox bimetal blades. The bimetal ones will not be wrecked if you hit a nail, and can be resharpened a number of times. They will cut far longer than other blades as well.
I purchased a 3/4" carbide tipped blade from Laguna Tools several years ago. I had them sharpen it about two years ago after I hit a nail in a piece of wood. I use it almost daily and it is still sharp. Really good for resawing as well. Pricey at well over a dollar per inch, but worth it in my view Have not tried the so called bimetal blades. Tom
Bought a Morse 3/4" x3 x 158" last year through Spence distributors. ($126) Worked great until it broke. Spence so far has not responded but it was certainly a good price and US made.
Laguna LT18 was set up correctly and at time of break was cutting 4" thick wet oak. I had previously been re-sawing 14" thick black walnut with no problems and yes it cut 1/16" veneers and produced a surface suitable for gluing with no clean up necessary
I think that the Laguna blades are actually stellite tipped, which is a material that is not quite as hard as the carbide. Their blades can be sharpened a few times. Most of the tipped blades do not have the set/side ways bending away from the blades that the typical resawing blades that are really specialized for resawing wet wood, and the chips and shavings don't clear as well. My 150 inch by 1 1/4 by teeth at 3/4 inch apart were under $70 last time I bought them, and the carbide tipped ones were about $170. My 96 inch blades for my little saw were about $27. The bimetal just lasts a lot longer. Not to the extent that the CBN wheels out last standard grinding wheels, but still, more bang for your buck.
I did spend some time on the phone with a Lennox rep today asking why their blades are not marketed to the woodturning world a lot more. I think they cater more to commercial businesses and portable band saw mill people, and not the hobby world. They do have a lot of independent reps as well. Don't know if I convinced them they need to check us out or not.
I too have a Laguna blade carbide or what ever it is, the 2nd actually, since the first seemed so dull, it was in my opinion dangerous to use. So they sent me another one and I haven't changed my opinion. So I got the Woodturners 3/8" blade from Highland Hardware and use it to cut daily. YMMV
Mike, on the south side (Hull Street) you have Automatic Saw. They'll weld blades for you at a very good price. I pay $17 for my 105" blades (1/2"), and each one typically will cut a couple of cargo trailer loads of wood, and that's all I expect from a blade. Lately I've discovered I can extend blade life quite a bit by resharpening. I simply raise a burr on the tips of each tooth by running the blade manually backwards against a diamond card file.
I've haven't checked into real resharpening a la Robo Hippy.
I pay $6 for 105" 3TPI 1/2" blades. I cut a lot of wood with one before it has to be tossed. I ruined 2 high dollar blades trying to cut green wood, they bend too easily. I save those for resawing and they never touch green wood.
He's just a local saw sharpening service but his sharpening is better than the other high quality places that I tried and he's far less expensive. His main incomer comes from sharpening industrial bandsaw blades. You know how much fun (and dangerous) it is to roll up a bandsaw blade. I've watched him roll one that is about 4" wide and god knows how long, and he rolls it up twice so there are like 6 loops ready to jump out and kill you.
Anyway at the current time he makes the 1/2" blades for me at $6 each. I need to go over there this week and get some saws blades sharpened so I'll check. Unfortunately he doesn't have any e-mail or website.
