More on 3 point tool and beading
I spent quite a bit more time on the 3 point tool turning bead yesterday and learned a few things. If you raise a burr it cuts pretty clean even on the endgrain and glue joints of my segmented pieces. The burr doesn't last long but will do a few beads. I raised the burr straight off the grinder and of course if you grind all 3 sides you wipe the burr off some sides so you have to start a cut and see if it is one of the burr sides. You can tell instantly by the shavings. If no shavings then rotate to another side.
Polishing the burr off. This is the way I usually use this tool It leaves a good edge on all the sides. However mine dulls pretty quickly and didn't seem to last as long as the burr. It is a homemade tool and was hardened but it's high carbon steel and that may be part of the problem. May have to talk Doug Thompson into selling me a hardened particle metal rod to make another one. Once it gets dull it tears the wood and this happens way too quickly on mine.
I tried the skew on it's side. It cuts very clean and the edge lasts a fairly long time. Of course the edge is a 40 degree included angle vs the 3 point tools 120.
So the 3 point tool will give you a clean bead but the edge needs to be refreshed often if your doing more than one bead. A detail gouge will cut a clean bead every time but of course there is some skill building involved in cutting a perfect bead, especially on the edge of a platter. To help with turning a bead on a platter raise your tool rest way above center. It lets you cut the bead with the same techniques you would on a spindle. With the tool rest lower it's impossible to roll the tool over the bead on the inside cut, you have to really swing the handle which is harder to control.
Re: More on 3 point tool and beading
Jeff Smith
Couldn't you use the butt end of a tool you already have?
Jeff I don't follow you?
Jeff Smith
John: I was merely speculating that if you wanted to grind your own, you could use the butt end of a tool you currently have laying around. That is, if your tools are in removable handles. It would be cheaper and faster than waiting for the mail .
Got ya. I probably own 75 or more tools but surely your not suggesting I have some I don't use. :) OK maybe some are just there for wall decoration but they are useful. Or at least could be. Pretty sure some tools will go to the AAW for the box that they are going to send to some country for teaching purposes. I could not find the notice on that to post it. Maybe someone else could. I need to find it because I want to announce it at our club meetings. Since I'm going to the symposium I can take the tools with me. (of course if anyone turns in a Stewart Batty tool it might get lost on the trip) :)
Re: More on 3 point tool Photos???
Lyle Jamieson
Lyle Jamieson
Most HSS manufacturers do not harden the tang or handle end of the tools. Most will have soft metal down there so it will not hold an edge like HSS.
About 7 minutes in is my 3 point tool  *LINK*
https://www.youtube.com/watch?v=bjYehUsMdB4
