OT - Compressor Question
Charlie Anderson
My compressor is small but according to the gauges has 100 # pressure. Why can't it inflate a truck tire?
Charlie Anderson
2 issues
1) If the tire is tubeless and the rim is not in contact with the rim all the way around neither your or any other compressor will inflate it. Take a band clamp, run it round the tread surface, tighten it up as best you can, retry tor air.
2) be patient. It's volume of air, not what the pressure gauge reads, that inflates the tire. Once you have the rim sealed to the bead on the tire, your small pump will inflate it; just takes longer than at the tire store.
Re: 2 issues
Charlie Anderson
This is an already inflated tire. I'm trying to get it from 28 psi to 35 psi. When I connect it to the tire, nothing happens. (I already had the compressor pressure up to where it had shut itself off.)
The reason I wanted to use it is my boat trailer tires are very low but decided I'd test it in the garage before heading to the boatyard.
Re: 2 more issues
Either your regulator valve is shut off (no air going down the hose) or your air chuck is blocked.
Try pushing the valve stem
steven antonucci
Sometimes, they seize. I always had issues with bike tires, so I always pushed them in first to let some air out and unfreeze the valve.
Operator Error
Charlie Anderson
So I decided to try again, but still no luck. I was looking at the compressor and wondered what the TWO gauges were. I'd been reading the tank pressure, ignoring the other gauge. As I'm sure everyone knows, it was the output pressure. So I twisted the knob next to it and, voila, the needle moved up. Set it to 80 psi and tested it on the truck. And of course, it works just fine.
Thanks for the help.
How unusual
PEBKAC
Computer geeks have a term for an analogous situation: "PEBKAC -- Problem exists between keyboard and chair." Glad you figured it out.
DAMHIKPEBKAC
Re: Operator Error
phillip medghalchi
Just imagine if you did all the other solutions.
